Re: Stock 904 okay behind mild 340? [Re: Lil Wedge] #534276
11/23/09 11:11 PM
11/23/09 11:11 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
The Cuda with 360 and 904
Re: Stock 904 okay behind mild 340? [Re: Lil Wedge] #534277
11/23/09 11:24 PM
11/23/09 11:24 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
My 904 is stock though.. dont think its going to hold up to a wheel stander lol.
Re: Stock 904 okay behind mild 340? [Re: derekeh] #534278
11/23/09 11:36 PM
11/23/09 11:36 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Mine is too!! Only thing I do different is a better clutch and steels. I have run stock clutches before, no problems, They work, Only way your 340 will hurt that trans is if the trans is already worn out. The Wheelstand pic was to show you what they will take and keep on going. Besides you will pick some power going from 727 to 904, usually 1-2 tenths in 1/4 mile, like a free 20-25 horsepower gain !!
Re: Stock 904 okay behind mild 340? [Re: Lil Wedge] #534279
11/24/09 06:40 PM
11/24/09 06:40 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I contacted SMR transmissions and the have simple
mods to have a killer 904 !
They only work on Mopar transmissions and torques
Dan
Re: Stock 904 okay behind mild 340? [Re: Wedgeman] #534280
11/24/09 06:46 PM
11/24/09 06:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're that concerned, just put the 904 in and run it easy until you've got the new 518 or 727 ready. Then start beating on it and make an honest attempt to kill it just to see if you succeed!
Re: Stock 904 okay behind mild 340? [Re: DaytonaTurbo] #534281
11/24/09 06:47 PM
11/24/09 06:47 PM
W
Wedgeman Offline
Wedgeman  Offline
W
To go where you haven't gone before ? GREAT IDEA !!
Re: Stock 904 okay behind mild 340? [Re: Wedgeman] #534282
11/24/09 09:19 PM
11/24/09 09:19 PM
5thAve Offline
5thAve  Offline
Stick with a 727. It sounds like you'll need some different parts anyway to use a 904 and you'll definately need a different driveshaft so even if you're planning on changing to a 518 soon anyway it would be easier to just get another 727 to use in the meantime.
Re: Stock 904 okay behind mild 340? [Re: 5thAve] #534283
11/25/09 12:18 AM
11/25/09 12:18 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I have everything for the 904 swap since I had a 904 behind a mild 318 a while back so thats no issue.
Re: Stock 904 okay behind mild 340? [Re: derekeh] #534284
11/25/09 12:56 AM
11/25/09 12:56 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Youll be fine. There isnt anything magical about a 340. It doesnt take much at all to get the power of a 318 to stock 340 ratings
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Stock 904 okay behind mild 340? [Re: 69L78Nova] #534285
11/25/09 01:25 AM
11/25/09 01:25 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Like i said earlier, drop in the 904 if you have everything, most that say don't run the 904 don't really know how much they will take, & don't give them the benifit of a doubt, to me, its the little brother to the 727, & deserves its right to be trusted as a stout little tranny that it "TRUELY" is!!
Just think of it as is what a TH350 is to the chevy crowd, those are some damn good trannies when built too. I really like the 904 personally.
The "only" reason chrysler installed 727s behind most 340/360 A bodies was, most people were going to thrash on those cars, & they knew even the stock 727 would hold up for warranty purposes (smart thinking), but that doesn't mean the 904 was a wimp, especially when beefed up.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Stock 904 okay behind mild 340? [Re: joedust451] #534286
11/25/09 01:29 AM
11/25/09 01:29 AM
Like i said earlier, drop in the 904 if you have everything, most that say don't run the 904 don't really know how much they will take, & don't give them the benifit of a doubt, to me, its the little brother to the 727, & deserves its right to be trusted as a stout little tranny that is "TRUELY" is!!
& I'm even putting one (w a jw ultrabell adapter) behind my 451 going into a 65 dart
Re: Stock 904 okay behind mild 340? [Re: derekeh] #534287
11/25/09 01:49 AM
11/25/09 01:49 AM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
360 in my Challenger with a 904 behind it.
Ran mid 12's on tires and put about 30k miles on it without an issue.
Plan to continue to use it when the car comes back out of storage in a year or two.
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: Stock 904 okay behind mild 340? [Re: derekeh] #534288
11/25/09 01:01 PM
11/25/09 01:01 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
No one has mentioned the biggest advantage I have seen with the 904/A500: Lower first gear ratio. With street/stock rear ratios, that lower first gear will take you off the line much faster.
Rebuild a 904 with Kolene steels and Raybestos frictions or the equivilent and it will, IMHO, last just as long as a 727.
Volare cop cars with the 904 did just fine with many fleet operations (city of Aurora, CO for one) putting in shift kits to firm up the sloppy shifting and adding life to the transmission. If anyone can kill a transmission, cops can.
Craig
Re: Stock 904 okay behind mild 340? [Re: denfireguy] #534289
11/25/09 03:21 PM
11/25/09 03:21 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Is there any decent low cost shift kits out there for the 904?
Re: Stock 904 okay behind mild 340? [Re: joedust451] #534290
11/25/09 05:45 PM
11/25/09 05:45 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Is 275 ok ?
Re: Stock 904 okay behind mild 340? [Re: joedust451] #534291
11/25/09 07:58 PM
11/25/09 07:58 PM
5thAve Offline
5thAve  Offline
A lot of people who say not to use them say it because of been there done that broke it. It really just depends on what car you have and how you're using it.
Re: Stock 904 okay behind mild 340? [Re: 5thAve] #534292
11/25/09 10:37 PM
11/25/09 10:37 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Well I put the 904 and have it all running.. we will see how well it does lol.
Re: Stock 904 okay behind mild 340? [Re: derekeh] #534293
11/25/09 11:12 PM
11/25/09 11:12 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
So what would you guys do if you had a 904 out of the car, and it was only going to have a stout 360 in front of it? What would change if anything?
