Re: Milling heads
[Re: 602heavy]
#533749
11/24/09 10:26 AM
11/24/09 10:26 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Spoke with Indy today , the guy says the CNCd heads come with 79cc chambers , the heads purchased without CNC work come out as 75cc , so these heads were obviously bought without any CNC work from indy (75cc) , looks like i only need to cut around .072" off.
Thanks again.
Do not ASSuME anything , you should them first before cutting .
Re: Milling heads
[Re: B G Racing]
#533751
11/24/09 12:59 PM
11/24/09 12:59 PM
Posts: 1,200 UK
602heavy
UK
We check all our heads before and after milling,the 440-1s usually come up 75cc+ with the heat range spark plug that we intend on running and usually 74ccs- with a soild plug.WE generally cut .041 to get in the 64/65cc range.
Bob ,this is where it gets confusing , you say .004" per 1cc , the link on the other thread on moparts say .004" per 1cc , Indy say .006" per 1cc , now i'm obviously gonna check before cutting , but how many take Indys advise & cut too much? , or is there a limit on milling wherby the '006" will change the deeper the head gets milled?
I don't see how the .004/.006 can be accurate due to the shape of chamber...................i would think milling would have to be done in stages , checking every so often.
Re: Milling heads
[Re: 602heavy]
#533752
11/24/09 02:51 PM
11/24/09 02:51 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
you can't go wrong by multiple checks
Re: Milling heads
[Re: 602heavy]
#533754
11/25/09 05:52 PM
11/25/09 05:52 PM
Posts: 4,209 New York
polyspheric
New York
Good point: the formula only works if the chamber walls are (nearly) parallel. Beyond that point, each .001" removed changes the volume less - and how far down the shape changes is something they should supply.
Boffin Emeritus
Re: Milling heads
[Re: B G Racing]
#533757
11/25/09 07:44 PM
11/25/09 07:44 PM
Posts: 1,200 UK
602heavy
UK
Yea Bob , i filled the chamber with 62cc , marked it then cut it , now i got 66cc chambers. Thing is , i cut .070" off the heads , this works out to .008" per 1cc , the heads were dead on 75cc before cutting , something don't add up. Thanks for all the input.
