Re: 9 1/4 rears; Can I do it?
[Re: Commando1]
#533728
11/23/09 10:26 AM
11/23/09 10:26 AM
Posts: 7,506 Az
Crizila
Az
It's not that hard, and there is plenty of info out there regarding how to do it. The big hurter is you will need some specialized tools - inparticular the long tools that go down the axle tubes to adjust the side bearings ( preload and back lash). You will also need a dial indicator w / magnetic base, large socket and breaker bar for tightening the pinion nut, yoke holding fixture, inch pound wrench, torque wrench. Too bad your not a little closer. I would loan you all my stuff. You can make a yoke holding fixture ( I did ) or use a very large pipe wrench. The other tools are general shop tools. When switching gears, I have always had good luck by using the original shims over again. Study the existing pattern. If it is not ideal, add or subbtract shims from the original shims ( do not go over .015" ) and you will usually only have to do it once.
Fastest 300
[Re: Crizila]
#533729
11/23/09 01:47 PM
11/23/09 01:47 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I knew I needed the slack adjusting tool (32 bucks on Amazon). The ring and pinion is a used set (90k mi.). Virtually no wear that I can see. Everthing els I have except the yoke fixture but I can figure that one out. Thanks for the advice. I'll probably go for it. If you hear this at 3:00 A.M., ignore it:
[Re: Commando1]
#533730
11/23/09 06:15 PM
11/23/09 06:15 PM
Posts: 7,506 Az
Crizila
Az
Wow. That's a good price. Mine are home made. Made 2 so I don't have to swap back and forth when adjusting. Been looking to sell a Yukon 3.90:1 gear set with under 5000 miles on it if you know anyone interested. Go slow when setting the pinion bearing preload. Once you come up against the crush sleeve, you will strain your milk - and once pinion bearing clearance reaches "0", it will take very little more tightening to reach preload.
Fastest 300
