Re: another stroker ?
[Re: lokalik]
#533671
11/22/09 06:48 PM
11/22/09 06:48 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Read this... http://440source.com/blockinfo.htm 383 is the weakest! Edit: dosen't mean a 383 won't make a good street motor...just the 400's have stronger webs and, side reinforcements. either will survive till cap walk becomes an issue... but that's another matter not the blocks fault ![](/ubbthreads/images/graemlins/Twocents.gif)
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: @#$%&*!]
#533676
11/23/09 12:41 AM
11/23/09 12:41 AM
R70RUNNER
Riverside, Ca
I'd like to get my hands on some 383 blocks to see if they can't be bored out as much as a 400. I wouldn't be surprised, especially if it were an older block. Cory
WHY??? If you think 383 piston selection inhales sharply! Look at what's available for the 400 STD bore ![](/ubbthreads/images/graemlins/runaway.gif)
[Re: lokalik]
#533678
11/23/09 10:40 AM
11/23/09 10:40 AM
RapidRobert
the 400 is a B and will have "400" on the machined pad on top close to the dist hole and on one side of the block in large cast letters. I just got one (bare block) from craigslist for $60 & it cleaned up at .030" & making a 451 w a 440 crank/rods/KB280 pistons which is much better cubewise than 400.
