ld340 for thermoquad modification #533625
11/22/09 05:12 PM
11/22/09 05:12 PM
az
stage3 Offline OP
stage3  Offline OP
az
Anybody have pics to post of an ld340 intake modified to fit a thermoquad carb. I know there is a diagram in an old Direct Connection catalog
but it is not clear to modifications needed. Thanks
Re: ld340 for thermoquad modification [Re: stage3] #533626
11/22/09 06:34 PM
11/22/09 06:34 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
I bought mine like this. Looks like it was trimmed to match the gasket.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: ld340 for thermoquad modification [Re: 73cuda340] #533627
11/22/09 09:41 PM
11/22/09 09:41 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I just did this one for a guy.
Someone JB welded the center divider back in.
This job makes a pretty good pile of chips.
I would consider the Weiand 8007 action dual plane, it already has the spread bore flange but it does require opening up runner exits (the roof is necked down to 318 size)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: ld340 for thermoquad modification [Re: Rapid340] #533628
11/23/09 09:51 PM
11/23/09 09:51 PM
az
stage3 Offline OP
stage3  Offline OP
az
I already purchased an ld340 in very good condition for $50.00. I have seen the direct connection diagrams which basically match the
two photos but they have the divider milled down.
Any input on this modification?? Thanks
