Re: We got our hemi heads back from Modern Cylinder Head. [Re: Bob_Coomer] #532955
11/22/09 07:00 PM
11/22/09 07:00 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Why don't they have the "cathedral" shaped intake? Is that tech passe', or is it a legal deal?
Re: We got our hemi heads back from Modern Cylinder Head. [Re: Bob_Coomer] #532956
11/22/09 07:15 PM
11/22/09 07:15 PM
Northeast, Arkansas
Dodgeman67 Offline OP
Northeast, Arkansas
Bob I will try to post another topic to get some feed back.
But I have two siamese blocks that both would go back standard 4.25 if I wanted to do that, and I have a stock hemi crank and one 4.15 stroke crank, these are Mopar Performance heads about 4 or 5 years old, will have to check the casting number.
I also have a set of 13.5-1 Venolia pistons and they are standard bore, and I have a set of aluminum rods for them, so my plan is to build a 426 with one of the blocks. I need some cam recommendations for it if anyone has any suggestions.
Back to the plan, we want to build this 426, put these heads on it, get our headers build and get everything worked out and then get the other block on the stand and we will probably sell the 4.15 crank and find a 4.5 or bigger stroke crank and build a 572 or something in that range and pull the 426 out, pull the heads off of it and put them on the big motor. I will keep the 426 short block complete for a back up engine, just in case.
This is out plan anyways.
I still need a cam, lifters, push rods, head studs, head gaskets, and a timing chain set, also will have to have a flywheel for an 8 bolt crank, for the power glide, and new slicks.
Does it ever end.
Re: We got our hemi heads back from Modern Cylinder Head. [Re: Dodgeman67] #532957
11/22/09 07:25 PM
11/22/09 07:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If you are interested in very large solid flat tappet cam and lifter set new in box from Barton (Bullet Cams)...Let me know..
Lifters are the Howards EDM AMC that will also oil through the push rod if you want it too.
I was going to do this and add restricters in the pushrods to fight some of the oiling issues people have had from Hemi from time to time.
Re: We got our hemi heads back from Modern Cylinder Head. [Re: Bob_Coomer] #532958
11/22/09 07:30 PM
11/22/09 07:30 PM
Northeast, Arkansas
Northeast, Arkansas
Thanks Bob, but I want a full roller and get all the power I can get out of it.
Our car is 2,600 pounds full chassis and we want to go fast. We run 1/8 mile and would like to run mid 5's with the 426 and low 5's with the other engine if that is possible.
Re: We got our hemi heads back from Modern Cylinder Head. [Re: Dodgeman67] #532959
11/22/09 10:48 PM
11/22/09 10:48 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
why dont you ask jeff about a cam?
Re: We got our hemi heads back from Modern Cylinder Head. [Re: ro23car] #532960
11/22/09 10:59 PM
11/22/09 10:59 PM
Northeast, Arkansas
Northeast, Arkansas
I did, I sent him all of my information today and I'm sure he will have an idea.
I have a couple months or so to get the rest of the parts gathered up, and hope to start the assembly process sometime in January and put it in sometime in Feb. get the headers built and the transmission rebuilt and get it to the track sometime in March or April if the weather is good.
Re: We got our hemi heads back from Modern Cylinder Hea [Re: Dodgeman67] #532961
11/23/09 02:06 PM
11/23/09 02:06 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Very interesting topic guys.
Fred that does sound very logical.
And I assume that's for the exhaust as well, leave them both alone, right.
Bob here is my flow sheet, not as good as yours, but should make go power. I will be posting up more of our combo later to see what yall suggest for a cam for this little engine.
Whats the dimensions and volumes?
Re: We got our hemi heads back from Modern Cylinder Head. [Re: Dodgeman67] #532962
11/23/09 02:13 PM
11/23/09 02:13 PM
an8sec70cuda Offline
Those look nice! Familiar too. I have the same heads (MP CNC'd by MCH) on my hemi. I didn't touch the ports or valve job when I got em back from Jeff. I just assembled them and bolted them on. They definitely make power. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: We got our hemi heads back from Modern Cylinder Head. [Re: mr_340] #532963
11/24/09 10:09 PM
11/24/09 10:09 PM
IL
knyech1 Offline
knyech1  Offline
IL
From my fluid mechanics classes in college many years ago, the air velocity right at the wall is zero (infinite shear stress would be required to have some velocity there), so I would think there is so little flow that close to the wall (within .010") that it wouldn't make much if any difference. Maybe they polish them to make them easier to clean and rebuild after each race?
ME grad and
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: We got our hemi heads back from Modern Cylinder Head. #532964
11/24/09 10:13 PM
11/24/09 10:13 PM
IL
knyech1 Offline
knyech1  Offline
IL
what I always believed
Port and polish Often mis-used term. Back in the early days, aport was ground as large as you could get it and then polished to a mirror like finish with the thinking that smooth was better for air flow. It also looked pretty. When flow benches came on the scene, it was discovered that the polishing part was actually hurting the port. The greater the air speed, the more it hurt.
How can that be? There is this thing called a boundry layer which is actually caused by the friction of the air as it makes contact with the port wall. This friction causes the air to tumble at the point of contact. Compare this to a wave reaching the beach. The closer it gets to the sand, the higher the wave gets until it collapses. Now, with a polished surface, the air does the same thing but because of the drag caused by the polishing (yes, drag), the wave height becomes so high that it effectively reduces the size of the port. Eventually, the wave can no longer support it's self and collapses, only to start over again. Now you have turbulence.
Air needs a lubricant to eliminate this drag. The best lube for air is a cushion of "air". Fine scratches perpendicular to the direction of flow act as a tripping point for the air that contacts it. The air tumbles at every scratch forming what is called a "boundry layer" that about the same size high as the scratch is deep. The air flowing in the port uses this boundry layer as it's cushion or lube and therefor is more resistant to turbulence. You can demonstrate this to yourself by pushing your finger over a mildly abraded surface and then a piece of glass.
So after all that, the "term ported and polished" has stuck with us even though "polishing" hasn't been done for over 20 years.
It's like I am reading my Fluid Mechanics book! Great explanation HEMIFRED I love these topics!!
