Re: Mini Starter Heat Shield or ?
[Re: moparphillie]
#531991
11/21/09 09:49 AM
11/21/09 09:49 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I found a starter heat shield wrap at my local NAPA store. I found it on their web sight and called them in the morning with the part number and then picked it up on my way home that afternoon.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#531992
11/21/09 10:27 AM
11/21/09 10:27 AM
Posts: 2,118 at large
moparphillie
at large
Thanks Dave, Do you remember the manufacturer and the part number ? I assume that you wrapped the starter, not the header with this heat shield wrap, correct ? Thanks again... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moparphillie]
#531993
11/21/09 07:52 PM
11/21/09 07:52 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I have had exactly the same problem with both my '65 Coronet big block and my '65 Dart small block. Both have mini starters from 440 source. On the big block I put a short piece of split heater hose between the starter stud and the block for insurance. I built my own heat shields fron thin sheet aluminum, thought that would solve the problem, but still have the problem on both cars. The Dart is race only, and it is so bad that it won't crank if I shut it off in the pre stage area. I am going back to a stock starter in that one, but a stocker won't fit my big block with the headers that I have.
This is the land of the free
because of the brave
[Re: moparphillie]
#531994
11/21/09 09:53 PM
11/21/09 09:53 PM
YO7_A66
Indiana
Phil, It does wrap around the starter and I found the info:
Starter Heat Shield, Thermo-Tec Automotive Products Product Line: Balkamp Part Number: BK 7353961 Price: $35.49 Each
[Re: YO7_A66]
#531995
11/21/09 10:05 PM
11/21/09 10:05 PM
moparphillie
at large
Thanks Dave, I sincerely appreciate your help. I will call my local NAPA store tomorrow. Two ( 2 ) more questions... How effective was this and was it used on a mini starter ? Thanks again... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moparphillie]
#531996
11/21/09 10:10 PM
11/21/09 10:10 PM
YO7_A66
Indiana
I don't have any actual results, but adding a thermal barrier between the starter and the header sure seems like a good move to me. I only have maybe 3/8" clearance at the tightest spot, so this cover has to help a little at least. I only had a few drives with it on and even then the outside temps were only in the 60-75 range. EDIT: Yes it was on a mini starter.
