throttle pressure/downshift
#531940
11/20/09 07:03 PM
11/20/09 07:03 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I finally completed the swap from my race 727 to a stock '65 727 in my '65. I used the downshift (throttle pressure) rod from the original 1965 273/904 setup. Just had to tweak the bends a bit because of the 1970 six pack setup being taller than the 273 2bbl. Adjusted everything per the service manual to basically where the throttle starts moving the transmission rod as soon as the throttle starts moving open. My question is: at full throttle, there is still room for the transmission rod to move further before it stops. Is this the norm? I never have figured why the trans rod is slotted at the carb attachment point.
This is the land of the free
because of the brave
Re: throttle pressure/downshift
[Re: MoparforLife]
#531944
11/20/09 07:32 PM
11/20/09 07:32 PM
rbstroker
West Tennessee
The linkage is pulled forward to the throttle pin, but the trans rod spring goes toward the front of the engine and the carb return spring goes to the back of the engine. Like in the drawing, at rest, there is no clearance between the throttle pin and the rear edge of the trans linkage slot. The concern is that at full throttle, I can still push the trans linkage at least 1/4" further back.
[Re: MoparforLife]
#531946
11/22/09 08:11 AM
11/22/09 08:11 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Just adjust it for wide open throttle with the transmission lever bottomed out.
If the partial throttle shifts are ok after that call it done.
The slot is for safety reasons. If anything holds the kickdown linkage open. You can still release the throttle and the throttle can close.
[Re: MoparforLife]
#531947
05/28/10 11:19 AM
05/28/10 11:19 AM
Posts: 114 Gainesville, FL
CSSRegistry
Gainesville, FL
hello all. i am having downshift troubles with my 64 D100 with a 440 and a 727 push-button 727. i have all the linkage set up similar to the illustrations above with a slotted rod and pull spring but i can not get it to downshift on its own at WOT. short of pulling the pan and taking a peek inside i can't think why it is not downshifting. please help! Ben ![](http://www.cssregistry.com/css/64d100Resto/2009-12-24_WrappingUpDrivingAround/DSCF0043.JPG)
1963-1967 Dodge Custom Sports Special
and High Performance Package REGISTRY
