Pot Metal Restoration Advice/Vendor #531486
11/20/09 12:00 AM
11/20/09 12:00 AM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
All of the DODGE and CORONET lettering on my 67 Coronet needs to be restored/rechromed. Any good vendors out there in Mopar Land that restores Pot Metal? Thanks!
p.s. I'd also consider repops but I can't find them anywhere.
Re: Pot Metal Restoration Advice/Vendor [Re: WAJ] #531487
11/20/09 02:09 PM
11/20/09 02:09 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Based on the parts I've had done, and I've seen others have done, rechroming pot metal parts yields a part that is only OK at best. The material is soft and usually pitted. Stripping off the old plating, polishing and replating softens most (if not all) of the crisp edges.
Especially on letters (I doubt anyone would even sign-up for that) that are so small.
Iverson states he can do this, but I wouldn't trust him with anything of mine.
Re: Pot Metal Restoration Advice/Vendor [Re: WAJ] #531488
11/20/09 03:55 PM
11/20/09 03:55 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
These guys did the original door handles, vinyl-top checkmark moulding and rear taillamp panel trim for my '68 Charger R/T. The outcome was great and on original parts. I posed the question about repair and replating of pewter/potmetal components. They said they could do it. They specialize in a lot of older classics that had heavy chrome accents...
http://www.superiorchrome.com/
Hope this helps....
Troy
Troy
Houston Mopar Connection Club
Re: Pot Metal Restoration Advice/Vendor [Re: hemi68charger] #531489
11/20/09 10:47 PM
11/20/09 10:47 PM
central ohio
mopar rookie Offline
central ohio
I had Customchrome Plating in Grafton Oh do mine. I just picked them up today. They look good.
Re: Pot Metal Restoration Advice/Vendor [Re: mopar rookie] #531490
11/20/09 11:43 PM
11/20/09 11:43 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
All the potmetal on my 68 Newport is junk.
There is nobody around here (in Canada) that can do potmetal.Depending on its condition,it may dissolve in the tank!!
I got my hood lettering used from a California car and is not pitted.
Also a good friend in Arizona shipped me some really nice trim from a car he parted out.(Thanks Chris! )
I have located on E-bay the rest of the trim I needed in new old stock.
It is not easy tracking down NOS parts for a one year only and one model only part.
Especially when it is a C body.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Pot Metal Restoration Advice/Vendor [Re: 68Cbarge] #531491
11/20/09 11:52 PM
11/20/09 11:52 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Fini Finish in Warren Michigan does a nice job but you better have deep pockets...Pot metal sucks to restore..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Pot Metal Restoration Advice/Vendor [Re: RP's R/T's] #531492
11/21/09 02:01 PM
11/21/09 02:01 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
What happens is:
The chrome is striped, then copper is plated onto the part, then the copper is sanded shaped and if needed it is done muti times.
After done a differant copper is plated on it followed by nickel and the chrome is done like clear over the nickel{triple plated}
A good shop{and high dollar} like Pauls will take the time and the part will be done right, and not look differant than it should. retain all the lines and shape. Someone who realy knows his job and is skilled must do it for a good job.
This is a long process even if done wrong and cost
The place in Tenn. does nice work as well "Advance"
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Pot Metal Restoration Advice/Vendor [Re: 340SIX] #531493
11/21/09 02:45 PM
11/21/09 02:45 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Advanced Plating and Powdercoating in Nashville does pot metal work, but they are super expensive. The work is top notch though.
Re: Pot Metal Restoration Advice/Vendor [Re: Neil] #531494
11/23/09 09:40 PM
11/23/09 09:40 PM
Southern Indiana
75RoadRunner Offline
Southern Indiana
Advanced Plating does do pot metal work, they are super expensive, but they are no way top notch. I am going to try Paul's the next time around.
Re: Pot Metal Restoration Advice/Vendor [Re: 75RoadRunner] #531495
11/23/09 10:04 PM
11/23/09 10:04 PM
So Dak
GOLDENCOMMANDO Offline
So Dak
Re: Pot Metal Restoration Advice/Vendor [Re: GOLDENCOMMANDO] #531496
11/24/09 08:54 PM
11/24/09 08:54 PM
http://iversonautomotive.com
He polished all my trim and restored my pot metal tail light bezels. Did great work.
Re: Pot Metal Restoration Advice/Vendor [Re: ] #531497
11/24/09 09:16 PM
11/24/09 09:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I've seen Iversons work as well as the other highly reccomended vendors here, any one of them is capable of fantastic work, however I've also seen examples of parts done by all of them that I wouldn't use simply because the parts in question fell below what I'd consider acceptable for an OE level car.
No matter who you use or what you pay, the results are likely to vary even from the same vendor as no two used parts are the same. Sometimes the parts condition simply leaves too little to work with in getting exacting results when compared to mint NOS. It's not always the vendors fault, some of the final expected results are simply beyond any vendors capability in trying to perfect a repair due to the parts intricate shape or extremely poor condition.
Pot Metal restoration is expensive because it's very tedious, and usually very time consuming work. It demands a HUGE attention to detail because even the smallest flaws or differences can easily show.
At any rate, plan on spending some big dollars, don't plan on perfection because you'll likey get let down at least a little, and if it were me, I'd get the best quality used examples to start with and I'd entrust my parts with Iverson.
Re: Pot Metal Restoration Advice/Vendor [Re: ScottSmith_Harms] #531498
11/25/09 02:58 PM
11/25/09 02:58 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Iverson does incredible work, he has restored several rare parts for me and they come back perfect in most cases, even some really rough stuff that I had came back nearly perfect and would pass any Concourse judging. Pretty expensive, but worth it.
Re: Pot Metal Restoration Advice/Vendor [Re: WAJ] #531499
01/25/10 03:49 PM
01/25/10 03:49 PM
Minneapolis, Minnesota
I
Iverson Offline
Iverson  Offline
I
Pot metal is very difficult and in most cases expensive to restore. There are a few people who know how to do it and many who do not. Not all pot metal can be restored and some pot metal that can be restored can't be brought back to 100%. Find someone who will drill out the pits and fill them with silver solder before plating. Many companies will try to grind out the pits and this is how you lose all of the detail, round off the edges and get trim back that is all wavey. One's own expectations may not be realistic when it comes to pot metal restoration. It is not like restoring bumpers or chrome steel, it is very labor intensive and if a part is a 1 ot 2 on the 10 scale it probably will never make it past a 6 after restoration. Start with the best pieces you can and if your trim is really bad and you can't fine better pieces then you have to be realistic about the outcome.
Re: Pot Metal Restoration Advice/Vendor [Re: Iverson] #531500
01/26/10 12:03 AM
01/26/10 12:03 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've had work done by two firms who, at best, cut corners by trying to do some of the fill in detail work by excessive copper plating, thereby softening the edges and corners. One couldn't get the chemistry right in the tank, and had decent plating ruined by off-gassing and bubbling lifted the plating. They ended up eating up a 69 GTX trunk bezel and never compensating me for it. So stay away from Nu Chrome in Fall River, Mass.
Good Pot Metal work is a lot like doing quality body work. The earlier line about drilling and filling is right on. The tough part is keeping the sharp edges - they get lost in the repeated buffing and replating of the copper coat.
If you can find NOS - PAY FOR IT. Otherwise, find the absolute best cores you can get. And then when choosing a plater, send them one or two pieces and test them out - don't give them your best or rarest pieces first.
