Holley Carb Help #530397
11/18/09 10:37 PM
11/18/09 10:37 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
so when i turn my car over gas puddles on the throttle plates of my front carb. (6-pack) I know its not a needle and seat and i know its not my fuel pressure. I did swap the front with the rear float bowls and im still getting the front one leaking. Any ideas what this may be? float level is OK
Re: Holley Carb Help [Re: kieron_kohlmann] #530398
11/18/09 11:29 PM
11/18/09 11:29 PM
I was going to say is the height of the sight plug the same between the 2 diff bowl but I reread & you had the prob w the orig bowl. I would look down there as someone cranks it (pull the pentastar connector off of the ECU) & see if the leak is obvious.
