My experiences with those fan switches that have a set on/off setting haven't been very good. I went through about 3 or 4 of them, some from different manufacturers and none of them when tested would turn on at their advertised setting. It was always about 5-10* higher.
I went with an adjustable unit from Derale (DER-16749) that was only about $40 and its adjustable from like 150-240* and turns off 15* lower than the turn on temp. It comes with the module, relay, and an option to wire in a kill switch.
