Made a change on the alt. pulley .. went from a 2.75" to a 2.50" alt. pully .. Seen a little change NOT much though. The dart does Idle real low though > 800rpm . Could turn the idle up a little. OR put the oem steel crank pulley back on or just live with it. just seems that with a low idle the e-fan and e-pump turn slower too. not up to max potenial . OH well !!
I did make a observation though >> with the newe fan and e pump installation this stroker is make MORE POWER
Awesome !!
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
