Re: AAR fiberglass fenders?
[Re: rck850]
#527165
11/15/09 10:28 PM
11/15/09 10:28 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Ive only used there hoods, scoops and bumpers. There quality was top notch. My body shop really complimented the quality. I wouldnt hesitate to use there fenders. I believe that they have the headlight buckets moulded into the fenders which is a major plus. If glass fenders is what you want, I would go for it. I used glass fenders from Glasstek before AAR had fenders and they were pretty nice also. They didnt have the headlight buckets which kinda made things difficult. I was shocked as to how lite the factory steel fenders were on my wifes Dart. I personally wouldnt use glass fenders again for an A-body. But like I said, if your gonna get them or you NEED them; I would have no problem using AAR.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: dusturbd340W5]
#527167
11/15/09 11:16 PM
11/15/09 11:16 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
I have a pair for a Duster. They are very nice.They have all the stock mounting points and the places for the headlight buckets.
Post deleted by Defbob
[Re: bigtimeauto]
#527169
11/15/09 11:27 PM
11/15/09 11:27 PM
#527171
11/16/09 05:10 AM
11/16/09 05:10 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
you can't lean on them and there's very little weight saving
What do you think the weigh savings is on a stock A-body hood vs an AAR glass or other brands hood?
[Re: autoxcuda]
#527172
11/16/09 07:32 AM
11/16/09 07:32 AM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Their good fenders, I have them on my car, but they are heavy, call them and ask how much they lbs ![](/ubbthreads/images/graemlins/apimp.gif)
[Re: B1KILLER]
#527173
11/16/09 04:49 PM
11/16/09 04:49 PM
Posts: 4,086 The Wet Coast, Canada
megajoltman
I not sure what a stock hood weighs but sure feels like a lot I think the biggest weight saving I think is going with a fiberglass trunk lid those stock one a very heavy. imo
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: slantzilla]
#527176
04/15/13 07:54 AM
04/15/13 07:54 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Very old post... what did you guys to with your headlight buckets? I have the AARs and they have a moulded in "bucket", but where/how did you mount your adjusters?
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
[Re: rck850]
#527177
04/15/13 10:48 AM
04/15/13 10:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you really want to save weight... go with carbon fiber... it cost way more but its stronger and way lighter... my fenders are 6# each and I thought about making them in carbon fiber but figured it would be way toooo much cost to save 2# max so I stayed with steel fenders and the carbon hood... fiberglass tends to move around in the sun if its made light weight ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dusturbd340W5]
#527180
04/15/13 09:28 PM
04/15/13 09:28 PM
Crazy68Dart
Canton, Ohio
Is that what those are for? ![](/ubbthreads/images/graemlins/smile.gif) Mine has them, but they were in the wrong position. The factory adjusters were too short as well. In fact, I could not find any adjusters that were long enough, so I had to make custom adjusters. I'm not sure if a got a set of "seconds" fenders or what. I got it worked out, just wanted to see how everyone else handled it.
[Re: Crazy68Dart]
#527181
04/16/13 01:01 PM
04/16/13 01:01 PM
Posts: 290 Norwalk Ohio
cudasteve68
Norwalk Ohio
Is that what those are for? Mine has them, but they were in the wrong position. The factory adjusters were too short as well. In fact, I could not find any adjusters that were long enough, so I had to make custom adjusters.
My trunk lock clip would not fit. Material too thick. Nothing a cut off wheel to the groove in the lock would not fix
[Re: cudasteve68]
#527182
04/16/13 02:44 PM
04/16/13 02:44 PM
MR_P_BODY
I primed my hood yesterday (AAR glass hood)thats going on the Rampage... that thing looks VERY GOOD... one more coat of primer and it should be ready... I wish it was a 1/8" longer on the back edge but I can live with it ![](/ubbthreads/images/graemlins/wave.gif)
