Who to order 10.5cr 528 hemi pistons from?
#527046
11/15/09 08:17 PM
11/15/09 08:17 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
It's time to order pistons for the 528 hemi. Who should I order them from? I'm looking for 10:5 cr.
Chris from New Jersey
Re: Who to order 10.5cr 528 hemi pistons from?
[Re: fig426]
#527052
11/16/09 11:48 AM
11/16/09 11:48 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
Diamond pistons. ![](/ubbthreads/images/graemlins/thumbs.gif) CHIP
[Re: HemiRick]
#527053
11/16/09 07:06 PM
11/16/09 07:06 PM
Posts: 662 Tampa FL
hemibeep
Tampa FL
I am tired of my blue smokin cummins motor
What are you replacing the pistons, the rings are the problem....Cummins Hemis had the barrel edge worn off the factory rings from too rough a cyl wall finish...It just needs rings. Unless you just want to increase the compression .25 pt.
Would you happen to have part numbers to help me find the correct rings? It would be nice to correct this problem..
[Re: hemibeep]
#527054
11/17/09 11:35 PM
11/17/09 11:35 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
Hemibeep, I am going through the exact thing you are. My Cummins 528 was purchased by me off another member here for a good price, but I knew from reading here, that tearing it down and redoing it was mandatory. The clearances on the valve guides were so loose that all the valves had horrible oil/carbon buidup on the backsides, I have never seen anything like it. Cummins also did not use a torque plate when honing, it was obvious. They also left out the windage tray and the engine build was somewhat less than sanitary. I had everything checked and my shop did a lite hone on the cylinders. I am using Speed Pro plasma-moly file fit rings, PN# R-10595. The engine is assembled and I am waiting on Smith Bros. for my pushrods, MP's were .075 avg. too short and had over 4 threads showing under the rocker. I hope to have her in the car and running in the next couple of weeks, I will let you know how it all works out, but I think what you have is salvageable by new rings and valve guides if yours is like mine. Lee.
