MSD distributor and Mopar ECU
#526612
11/15/09 12:22 PM
11/15/09 12:22 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I am just curious, isnt an MSD distributor just an electronic pickup, simililar to a stock Mopar distributor? If thats the case, could you just wire it up to the stock Mopar electronic ECU setup in place of the stock distributor?
Outcast Dodge guy.
Re: MSD distributor and Mopar ECU
[Re: 85_Ram_4speed]
#526613
11/15/09 12:28 PM
11/15/09 12:28 PM
Posts: 3,399 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Should be fine.
I run the opposite setup with no problems--Mopar dist with MSD box. Just had to swap a different electrical connector.
I was using the MSD dist but it was too tall and I missed my vacuum advance.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 85_Ram_4speed]
#526614
11/15/09 01:21 PM
11/15/09 01:21 PM
RapidRobert
yes just a different dist supposedly of better quality (I have never owned one) but I do know alot of MSD's stuff is now being made over there. I'd mainly want one that the springs/curve is easilly accessed
[Re: wingman]
#526615
11/15/09 02:05 PM
11/15/09 02:05 PM
Posts: 1,261 ILL
mark7171
ILL
Should be fine.
I agree. That vacuum advance was nice.
Try the GM HEI system. I use on my 4dr 323", the 4-pin HEI gm unit is cheap. A fellow mechanic replaced them falsely accusing the part. Got myself a handfull. I feed the pin + unit battery volatage, and the hook up the coil w/ballast via the 4-pin. With a MP hei vac adv, its self contained fully curvable unit.
