Confused on Decoding 1968 Build Sheet
#525562
11/14/09 03:29 AM
11/14/09 03:29 AM
Posts: 2,782 USA
JoesMopar
USA
Any of you guys know how to decode these things?
Example:
it gives me: Engine 37-38 62
So since it's a RM23H Road Runner I looked up E62 and it's a 383 HP, but what does 37-38 mean?
But, when I look at the Sure Grip option:
Sure Grip 408 8
I look at 408 which specifies Sure Grip, but what does 8 mean?
Or this:
Trans 39 3
How do you decode this? It's in line after Engine (32-34 37-38 39?) What do those numbers in numerical order refer to? What does the stamped number, in this case 3, refer to.
It appears under the part/option/trim whatever, there are numbers increasing in numerical order, ex. 509 510 511 512 514 515 516 etc in these cases it's lighting options. What do those mean throughout the build sheet? What does the number below it thats stamped/typed mean?
Some are in the 100's, some in the 10's, like 52 53 54 55 56 etc.
Also, at the bottom of the sheet it has this:
Engine Trans Axle Pinion Wheel etc etc 760 100 244 32 16B
How do you decode these also?
I have tons of questions on this but maybe learning these will help. Thanks for any help
Re: Confused on Decoding 1968 Build Sheet
[Re: JoesMopar]
#525563
11/14/09 05:14 AM
11/14/09 05:14 AM
Posts: 1,183 eganville ont
440beep
eganville ont
- 8 = sure grip (both rear wheels have power)
3 - 4-speed maunal floor shift (A833)
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 268RTs4ME]
#525565
11/14/09 11:22 AM
11/14/09 11:22 AM
Posts: 2,782 USA
JoesMopar
USA
Ok, I think I figured this out:
ex:
Radio 42 1
This would mean look in the 42? series and find 421 to see what kind of radio.
HD Brakes 47 8
This would be look in the 47? series and find 478
Is that correct?
The triple digits, 509, 511, 512 etc you look up just by thoe numbers, but I still don't understand what the typed number below it is.
Ex:
Glove Box Lock 509 9
I look up 509, it says glove box lock, ok, but what does the 9 specify? Maybe color?
Ex:
Turn Ind/Fender hood 517 7
Again, I look up 517, see the turn signal option but what does the 7 under it mean? Surely it isn't color here, how could it for a turn signal?
Another thing that's weird:
Tires 43-44 46
So this tells me look up 46 and I find F70-14 Red Streak Tires
But, it also has this:
Hub Caps/Wheel Covers 58 1
So I look up 581 and find 15 inch deluxe wheel cover.
How can there be a 15" wheel cover on tires specified for 14" wheels???
I'm still clueless on the bottom of the sheet with the codes I listen in my original post
Here's some more at the bottom:
Wheel Covers 10
Torsion Bar Left Right 779 778
Rear Springs Left Right 212 212
Clutch and Brake Bracket 25
Front Brake 25
Steering Wheel and Horn Ring 12F
Steering Column 35F
Stub Frame 16
Engine Fan 24
Engine Fan Spacer 32
Rad. Inlet Hose 01
Rad Outlet Hose ?1
Carburetor 25
Carb Choke 45
F G H J K L M N 2|3 (this is under the N, rest are blank)
Vac. Fit 25
Sway Bar 5
Rad. 43
P Q R S T
under Q is Cap Idle Label with 44 under it
Under R is 5|4
Thanks for any and all help.
[Re: JoesMopar]
#525566
11/15/09 03:22 AM
11/15/09 03:22 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
ex:
Radio 42 1
This would mean look in the 42? series and find 421 to see what kind of radio. Yes
HD Brakes 47 8
Is that correct? Yes
Ex:
I look up 509, it says glove box lock, ok, but what does the 9 specify? Maybe color? That is a 'yes' or 'no' option. If the last number appears in the box, the car got the option. If the 9 did not appear in the box, the car did not come with the option
Ex:
Again, I look up 517, see the turn signal option but what does the 7 under it mean? Surely it isn't color here, how could it for a turn signal? Same thing. It's a 'yes' or 'no' option.
Tires 43-44 46
How can there be a 15" wheel cover on tires specified for 14" wheels??? Code 581 only tells you Deluxe wheel covers, it does not tell you the size.
Wheel Covers 10 The last two digits of the part number for that specific entry. In this case, 10 means Part number 2823010
Torsion Bar Left Right 779 778 last three digits of part number. One for left and one for right
Rear Springs Left Right 212 212 last three digits of part number. One for left and one for right
Clutch and Brake Bracket 25 The last two digits of the asasembly number for that specific entry.
Front Brake 25 The last two digits of the part assembly for that specific entry.
Steering Wheel and Horn Ring 12F part number and color F=green
Steering Column 35F Assembly code and color
Stub Frame 16 Assembgly code
Engine Fan 24 The last two digits of the part number for that specific entry.
Engine Fan Spacer 32 The last two digits of the part number for that specific entry.
Rad. Inlet Hose 01 The last two digits of the part number for that specific entry.
Rad Outlet Hose ?1 The last two digits of the part number for that specific entry.
Carburetor 25 The last two digits of the part number for that specific entry.
Carb Choke 45 The last two digits of the part number for that specific entry.
Vac. Fit 25 The last two digits of the part number for that specific entry.
Sway Bar 5
Rad. 43 The last two digits of the part number for that specific entry.
P Q R S T
under Q is Cap Idle Label with 44 under it the last two digits of the part number for the label that goes under the hood of the car showing the idle specs
Under R is 5|4 Tire label???
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
