Aluminum vs Steel Replacement Driveshaft Question #525473
11/14/09 12:41 AM
11/14/09 12:41 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
I am going to order a new driveshaft Monday from Dynotech and wondering is there any advantage in going with an aluminum one over a steel replacement?
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525474
11/14/09 12:47 AM
11/14/09 12:47 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Less rotating mass in the drive train.
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525475
11/14/09 11:08 AM
11/14/09 11:08 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It's an improvement, but it's worth very little. Don't expect to see it on your timeslip.
Why:
1. Small mean radius of gyration = low moment of inertia (compared to a clutch disc, converter or ring gear)
2. Low RPM through almost all the race (compared to anything in front of the transmission)
Boffin Emeritus
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525476
11/14/09 11:12 AM
11/14/09 11:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have their aluminum shaft, saves a few pounds of spinning mass. I would buy another one. great product and custmer service
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525477
11/14/09 12:47 PM
11/14/09 12:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on what your doing with the car, if you want it to be as fast as posible I have seen many NHRA class cars pick up MPH and reduce ET by using a lighter driveshaft than a heavier one on back to back test A 10 lb. difference in weight loss makes more gain than a 5 lb loss (reduction) does
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: Quicktree] #525478
11/14/09 12:50 PM
11/14/09 12:50 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Sounds like I should stick with a steel replacment one. I was told that the diameter will need to increase by .050 going with aluminum over the stock piece. Any other suggestions as I have the measurments and will be placing a call first thing Monday morning.
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525479
11/14/09 03:18 PM
11/14/09 03:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I would also assum an alum driveshaft would do less damage then a steel one upon a driveshaft failure, with or without a loop, and CF doing the least damage.
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: jcc] #525480
11/14/09 04:13 PM
11/14/09 04:13 PM
I went with a mark williams aluminum driveshaft with 1350 yokes on both ends and it was a smart choice. picked up a little, MW has great customer service and i'd buy another one in a heartbeat.
i like the light weight over the steel shaft.
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: SCATPK] #525481
11/14/09 04:26 PM
11/14/09 04:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Does a lighter driveshaft balance better and give off less harmonics at cruising. Like it could be quieter.
I see aluminum used is OE cars and I doubt it's just for weight. I see short cars like new mustangs with split double driveshafts. I assume thats for noise and vibration??
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: autoxcuda] #525482
11/14/09 05:09 PM
11/14/09 05:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since alum usually requires a larger(next) diameter, it likely would be stiffer and therefore less harmonics, etc or they would be a higher freq. One of my cars has a MW bonded alum/1350, which I like, I asked them years ago about lightweight foam filling an alum bonded driveshaft, they just gave a funny look.
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: jcc] #525483
11/14/09 06:43 PM
11/14/09 06:43 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Sounds like the aluminum unit may be just a tick lighter but also opens up potential clearance issues with exhaust. Any other pro or cons with one or the other. I figure I am going to spend the money and want to make a smart choice.
Re: Aluminum vs Steel Replacement Driveshaft Question *DELETED* [Re: jcc] #525484
11/14/09 06:57 PM
11/14/09 06:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: polyspheric] #525485
11/14/09 08:15 PM
11/14/09 08:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
No, aluminum is far less stiff than steel and needs the diameter to even be comparable; more wall thickness makes up the remaining difference.
my 3.5" aluminum shaft is rated to over 1000hp
Re: Aluminum vs Steel Replacement Driveshaft Question [Re: Quicktree] #525486
11/14/09 08:27 PM
11/14/09 08:27 PM
408Dust Offline
408Dust  Offline
Critical speed is the deciding factor in drive shaft material selection. Aluminum increases your critical speed rating, there is no real performance advantage to it other then raising the critical speed rating.Call Mark Williams, PST etc and give them your drive shaft length and maximum RPM at the stripe and see what they say.
