Re: Noob air pressure question
[Re: dmerc]
#525121
11/13/09 06:42 PM
11/13/09 06:42 PM
Triple Threat
Renton Washington
Start at 18 lbs, that should get you close. Theoretically you want to run as much air in them as possible. I run mine between 16 and 20.
[Re: dmerc]
#525123
11/13/09 09:32 PM
11/13/09 09:32 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
The best way I've heard to get the ideal pressure in a radial tire is by looking at the contact patch.
Find a clean piece of concrete where you can lay a set of tracks. (Asphalt works to but can be harder to read.)
If the tracks are darker in the middle and lighter on the side than the pressure is too high. Darker on the side and light in the middle means it's to low. Look for a nice even patch that's uniform all the way across.
Please find a place where you can do it safley and legally.
[Re: WILD BILL]
#525124
11/14/09 09:49 AM
11/14/09 09:49 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
We run 275's on a 10 inch wheel on the Duster and 315's on a 12 inch wheel on the Coronet and 17 seems to be what the Mickey T's like.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
