FYI..
with any SB lunati cam you can use the comp 901-16 springs
all the lunati SB cams use the same lunati spring across the board
901-16 springs drop on with stock retainers and seals with no machine work and can be done with out r&r the heads
the lunati springs are a double with a damper and need seals and machine work to use them
I went this way when going to the lunati 60710 voodoo roller cam in my 318 after I got the cam and springs from lunati...then got the comps springs
they are within 10 lbs of each other,I have been to 6200 rpms with it with no valve float,all though the cam noses over after 5500rpm
just had to try to see if they would float
but they are good to go
I would use the comp 901-16 with the mopar cam also,IMHO
they are good up to the .500 lift range
I have a 360 with the lunati bracket master 292/292 cam with the comp 901-16 also
way cheaper..comps are around the 79$ mark and the lunatis are around the 130$ mark...of couse results vary with the speed shop prices
good luck
