518 into 70 cuda questions #524856
11/13/09 10:39 AM
11/13/09 10:39 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
A friend is wanting to trade a 518 to some parts I have. Its a pre 96 lockup tranny. One thing im concerned about is the slap stick shifter I just installed in my cuda. Is it possible to use this or do I have to use a different shifter? Id really like to keep it if possible and mount the OD on/off button somewhere on the console possibly.
Another question... he doesnt know how many miles are on the transmission or if its ever been rebuilt. What can I look for to tell if it needs rebuilt prior to installing it? Or should I just rebuild it anyways. If so Id like to try rebuilding it myself since Ive always wanted to learn this.
Re: 518 into 70 cuda questions [Re: derekeh] #524857
11/13/09 12:14 PM
11/13/09 12:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think you'll be able to use that shifter as there is no place to mount the trans bracket on the 518. You would also have to do some cut and replacement of the floor tunnel to get it to fit and you'll need to build a crossmember.
Re: 518 into 70 cuda questions [Re: stumpy] #524858
11/13/09 12:27 PM
11/13/09 12:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You don't need to cut the tunnel, you do need to fabricate a new croosmember & if your willing to do the work the shifter can be converted to cable shift..
Re: 518 into 70 cuda questions [Re: stumpy] #524859
11/13/09 12:27 PM
11/13/09 12:27 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
What Stumpy said. Also if you decide to go with the 518 just rebuild it rather than betting on an unknown condition. I've only done a 727 but there is supposedly a nasty 800lb pressure spring in the OD unit that has to be handled properly or it can cause personal injury. Hopefully someone else will jump in here with more info.
Re: 518 into 70 cuda questions [Re: 1_WILD_RT] #524860
11/13/09 01:20 PM
11/13/09 01:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
