smallblock full groove to 3/4 groove main's..... #524328
11/12/09 07:07 PM
11/12/09 07:07 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
any one see any oil pressure improvement's by switching, everything else staying the same??
Re: smallblock full groove to 3/4 groove main's..... [Re: dartman366] #524329
11/12/09 07:34 PM
11/12/09 07:34 PM
ive never noticed any difference in pressure. a lot depends on your bearing clearances and any oiling modifications done to the block and/or pump.
Re: smallblock full groove to 3/4 groove main's..... #524330
11/12/09 08:19 PM
11/12/09 08:19 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Main's are.003 and the rod's are .0028 rod side clearance is .032 if I remember correct, all oiling passages have been opened up, crossover tube in the lifter valley and block tapped and modifyed at the oil filter area for remote filter.
Re: smallblock full groove to 3/4 groove main's..... [Re: dartman366] #524331
11/12/09 11:29 PM
11/12/09 11:29 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Ive never ran full grove but last year when I put my motor back together I put the 3/4 grove in. 120M bearings. Oil pressure was the same. I will know more next time I tear it apart.
Re: smallblock full groove to 3/4 groove main's..... [Re: Hunted Duck] #524332
11/13/09 02:51 AM
11/13/09 02:51 AM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
dartman366 i am going to do the mods to the block for the remote oil filter.i liked the photos you posted on that. what is the idea of the lifter tube mod. I have heard of it being done but never seen what it looks like or what it helps.is it related to rpm.i am running a 360 .040 over with solid cam.always looking for things that help it live longer. thanks Brad
Re: smallblock full groove to 3/4 groove main's..... [Re: roadrunnerreds] #524333
11/13/09 06:52 PM
11/13/09 06:52 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
you block off the passage from the no. 1 main that go's up to the driver side galley and put the crossover tube in to feed that galley, help's to prevent oil starvation to the no. 1 main, if I get a chance I will try and find the pic that show's the tube I put in.
Re: smallblock full groove to 3/4 groove main's..... [Re: dartman366] #524334
11/13/09 07:29 PM
11/13/09 07:29 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
here's a pic of the tube.
Re: smallblock full groove to 3/4 groove main's..... [Re: dartman366] #524335
11/13/09 07:30 PM
11/13/09 07:30 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
another.
