The specification for AN fittings is 37 degrees and the tube nut and sleeves should be for a specific O.D. of the tubing your using so # 8 tubing should be the same spec. regardless of which makers parts your using. I am mixing Fragola and Summit AN fittings on a project this week
I will let you know if I run into any problems with mixing them, I can't imagine them not working together
I have mixed tubing sleeves and nuts from other makers, Earls, Russel and Summits in the past and not had a problem with them sealing and working together, there is a slight color differences in the finish on them like Russel versus Summits
