Re: 383/509 cam
[Re: metcoll]
#523420
11/11/09 06:46 PM
11/11/09 06:46 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I would only recommend the revised lobe center version if you insist on using it.Much better camshafts available today.Esp in a 383.
Leave the gun.......take the Cannoli's....Mike
Re: 383/509 cam
[Re: Mr.Yuck]
#523421
11/11/09 09:40 PM
11/11/09 09:40 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
good combo depending on the rest of your set-up. 509 likes compression, stall and gear. Easy 11 second combo for an A-body 12's in a b-Body. I would NOT use it unless you have a 3200 stall and at least 3.91 gears. It is not a street cam.
Dam man it's a mild street for real men. for all out power the 108 LSA (cam centerline) for improved idle the 114. dual plane intake, 750 holley, headers best you can do with your heads but I ran 12.50 in my car when it was 3900 lb car and driver 10 to 1 448 cubes with just stock valves and .045 off the heads. With the 108 LSA on a 383 I would aim at 102 intake installed max lift (intake cenerline) 101 to 103 If you want a cam that will kick but on the street from 3000 to 6000 this is the cam for you. If you want a Honda Civic in wolves clothing like many of these girls in hear then a summit stockish cam is all you can handle!!!!! ![](/ubbthreads/images/graemlins/flame.gif)
Re: 383/509 cam
[Re: Dodgem]
#523422
11/12/09 02:37 AM
11/12/09 02:37 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Your comparing a 448CI with 10:1 (I'll ASSuME) 3.75" stroke? to a 383 with 3.375 stoke? Talk about apples and oranges ![](/ubbthreads/images/graemlins/popcrn.gif)
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 383/509 cam
[Re: Dodgem]
#523424
11/12/09 09:45 AM
11/12/09 09:45 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
my point 3-6k it works...it don't work well down low. And if you don't have compression, stall and gear it's worse. Depending on the set-up a summitt cam WILL work better.
