Blue/Gray underbody color for restoration #522447
11/10/09 01:04 PM
11/10/09 01:04 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
is there a formula for this color that someone has? Id like to do a factory style resto on my 69 dart and first up is the underside. Thanks
Re: Blue/Gray underbody color for restoration [Re: rck850] #522448
11/10/09 01:15 PM
11/10/09 01:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just a caution, A-bodies built at the Los Angeles plant had black primer underneath. Have example pics of three 68 Dart's with primo original undercarriages.
The E and B bodies may have been too.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Blue/Gray underbody color for restoration [Re: autoxcuda] #522449
11/10/09 04:07 PM
11/10/09 04:07 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Resto rick sells a paint in the correct color.
Re: Blue/Gray underbody color for restoration [Re: rck850] #522450
11/10/09 04:51 PM
11/10/09 04:51 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
....my '69 Dart had light green primer.
i don't think this was the anti corrosion dip because it covered the whole engine bay.
no grey anywhere and it was a south carolina car.
al
Re: Blue/Gray underbody color for restoration [Re: can.al] #522451
11/10/09 04:57 PM
11/10/09 04:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What assembly plant? The color varied quite a bit by location.
Re: Blue/Gray underbody color for restoration [Re: Alaskan_TA] #522452
11/10/09 05:32 PM
11/10/09 05:32 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Hamtramck
Re: Blue/Gray underbody color for restoration [Re: rck850] #522453
11/10/09 05:52 PM
11/10/09 05:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you can find a spot where it shows what your car had you should try & match it. That said....
Original samples that show the dip color(s) from three different 1969 Hamtramck cars;
Re: Blue/Gray underbody color for restoration [Re: can.al] #522454
11/10/09 06:12 PM
11/10/09 06:12 PM
WI
RestoRick Offline
RestoRick  Offline
WI
al
You'll likely find dark gray under the light green primer...
Rick
Re: Blue/Gray underbody color for restoration [Re: RestoRick] #522455
11/10/09 08:54 PM
11/10/09 08:54 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...when i started the resto, the engine bay was brush painted black.
i stripped it to either primer or right to the bare metal in lots of spots.
your probably right but i didn't see any grey.
there was lots of grey and green on my duster though.
al
