Do water pumps go bad sitting on a shelf? #522383
11/10/09 11:42 AM
11/10/09 11:42 AM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
I have a new small block water pump I purchased from Chrysler 24 years ago. Do you think its OK to use?
Re: Do water pumps go bad sitting on a shelf? [Re: 69MOPE] #522384
11/10/09 12:11 PM
11/10/09 12:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes
Re: Do water pumps go bad sitting on a shelf? [Re: 69MOPE] #522385
11/10/09 12:14 PM
11/10/09 12:14 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
It would depend on the environmental conditions of storage. Humidity being the one I would be concerned most with. Was it in the box? Put it on and try it. Use a good antifreeze/coolant with water pump lubricant or lube additive. Just don't go too far from home until your sure it's ok. YMMV
Re: Do water pumps go bad sitting on a shelf? [Re: Scott Carl] #522386
11/10/09 12:21 PM
11/10/09 12:21 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
I painted it when I bought it and put it back in the box. It was keep in an unheated garage. There is no evidence of corrosion. I was concerned with the possibility of hardened/leaking seal.
Re: Do water pumps go bad sitting on a shelf? [Re: 69MOPE] #522387
11/10/09 01:30 PM
11/10/09 01:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Use it.
Re: Do water pumps go bad sitting on a shelf? [Re: 69MOPE] #522388
11/10/09 02:20 PM
11/10/09 02:20 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
good luck. It may work just fine since its was brand new. I had a slightly used one that was sitting for 10 years and it leaked like a sieve when I installed it.
and the starter that had previously worked all of a sudden (after 10 years) didnt work either.
In my case the seals dried out and leaked. maybe the shaft got surface rust on it. on start up, the seal got destroyed.
