torque converter & idle #522335
11/10/09 08:02 AM
11/10/09 08:02 AM
windsor, onatrio canada
metcoll Offline OP
metcoll  Offline OP
have a 440 bored 030 with the six pack pistons, lunati 30307 cam mild 452 heads complete msd 750 holley dbl. pump, 1/34 headers,just had tranny rebuilt with tg2 shift kit & 4200 stall converter just wondering why idle speed has gone from about 850 to 1100 rpm in gear....thx
Re: torque converter & idle [Re: metcoll] #522336
11/10/09 08:24 AM
11/10/09 08:24 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
New TQ?? it will be looser promoting better idle tendencies. And the air is better this time if year sometimes effects the idle to. Cold clear air good!
Re: torque converter & idle [Re: metcoll] #522337
11/10/09 10:50 AM
11/10/09 10:50 AM
What specifically was changed from when it was idling @850?
Re: torque converter & idle [Re: RapidRobert] #522338
11/10/09 12:37 PM
11/10/09 12:37 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
Possible vacuum leak/ line left unhooked somewhere
Re: torque converter & idle [Re: donbarnes] #522339
11/10/09 01:09 PM
11/10/09 01:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
New converter has more slip at idle and doesn't load the motor so hard.
