Re: Gear drive for a 440?
[Re: Dodgeballs]
#522314
11/10/09 05:13 AM
11/10/09 05:13 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
There are a couple of different style gear drive set ups readily avaialble. One uses floating idler gears between the cam& crank gear, this kind of system usually fits under stock timing cover even though you have to "fit them", which usually means block and/or shaft trimming. I consider these flimsy, they have slack if you turn the crank back and forth, and they are not very reliable. I have used them in three engines, and have had troubles with two of them because of wear; they start trying to climb on a tooth, and in the other casedid & broke some teeth, valves etc. This was after some 20 000 miles. Don't know if this style is available for small blocks, but in big blocks the cam timing is done with offset bushings. Pretty easy to set up. Brands like Pete Jackson, Edelbrock and "no name" are available, I believe only for three bolt cams. Prices between around 100-250$.
The other style is a fixed idler, where is only one idler egar that in small blocks is fitted under the stock cover, and in big block comes with a cast cover where the idler gear is attached to. This is very accurate and super reliable. It's pretty easy to set up and the cam timing systen is genious and easy to change once you figure it out. there are some drawbacks though becausee of the thicker than stock timing cover, pulley alignment and damper depth may need trimming, and the price is considerably steeper.Available also for three bolt cams only.
Both of them truly makes some noice, I actually got fed up with it and in the futurer will only use quality chains or belt.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#522315
11/10/09 08:40 AM
11/10/09 08:40 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
We put a Pete Jackson in the kids 413 about 9 years ago.Its street driven and raced.No problems at all.He does put a ton of miles on it.It was an easy install.Like said you do need a 3 bolt cam.Rocky
Chrysler Firepower
[Re: Dodgeballs]
#522321
11/12/09 03:18 PM
11/12/09 03:18 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
As a completely different way to get the sound, I read about a guy that had a street rod. He wanted the sound too, but didn't want it all the time and have the issues with wear. He took an old AM radio and hid it. Then he mounted the antenna and a speaker under the hood. Last, he wired a toggle switch to the radio. When the radio was off, no sound. When he turned the switch on, the radio powered up, the antenna picked up the ignition noise, and the radio played that thru the speaker. Instant gear drive sound, with a volume control and the ability to turn it off when not cruising! A lot cheaper too! I'd imagine that selecting the right speaker and adjusting the tone control could get exactly the sound you want.
