Neon Tail lights #522295
11/10/09 02:50 AM
11/10/09 02:50 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Ant tricks to removing late 90's Neon tail lights? (without prying and breaking them)
I just pulled a broken one - and yes i removed the 4 nuts.
This thing had to be pried out! Lots of sealer / glue seemed to be holding it in.
Are they all glued in like that ?
Re: Neon Tail lights [Re: 493_DART] #522296
11/10/09 08:49 AM
11/10/09 08:49 AM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
Neons have always been known for water leaks past the taillamp gaskets. 9 out of 10 probably have the lamps siliconed in. Try a heat gun before prying. Use a non hardening sealing when reinstalling or double gasket them like I do. The dealer will tell you the gaskets are not available but they are. The part number is listed in a T.S.B.
Re: Neon Tail lights [Re: 69MOPE] #522297
11/10/09 11:35 AM
11/10/09 11:35 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I just started remaking those gaskets for 95-99 and 2000-2005 after a bunch of requests. The original material was the cheapest neoprene foam Chrysler could purchase. When the taillight was installed the 1/2" thick gaskets would be compressed 1/4" BUT the cheap material takes a set and never recovers. After a couple years when it shrinks the back floor starts filling with water.
I make mine out of the most expensive EPDM/Neoprene blend. EPDM is the stuff used on rubber flat roofs. It's 1/2" thick but soft AND resilient.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Neon Tail lights [Re: 71TA] #522298
11/10/09 12:50 PM
11/10/09 12:50 PM
I don't see them on your site? How much?
Re: Neon Tail lights #522299
11/10/09 01:01 PM
11/10/09 01:01 PM
Found em on Ebay!
Re: Neon Tail lights #522300
11/10/09 04:02 PM
11/10/09 04:02 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
My problem is not applying sealer or foam.
I need to PULL a light at the junkyard ---so No heatgun .
Re: Neon Tail lights [Re: 493_DART] #522301
11/10/09 08:32 PM
11/10/09 08:32 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
well, i got one today. Loosened the 4 bolts and it slid right out.
I guess someone must have replaced the one on my car previously and glued the $@#$ out of it !
