This is all going in a '68 Sweptline pickup (weight is between an a-body and a b-body).
The truck is street driven and makes runs to the home improvement stores but I enjoy giving nearly anyone who asks a run for their $$$.
Current setup.
440 auto
.040 pistons .100 in the hole (reuse and not changeable)
LY rods (pin fit)
Calculated compression is nearly 8.8:1 with .040 gasket.
Eddy heads (84cc)
Harland Sharp 1.5:1 rockers
Lunati 60303 Voodoo cam
Lunati lifters
Comp Cams pushrods
Cloyes double roller timing chain
Performer RPM intake
Holly 750 w/vacuum secondaries
Shorty headers (only set of long headers that will clear a '68 frame are over $600)
Dual 2" exhaust w/h-pipe and Cherry Bombs
MSD 6A ignition
Mopar adjustable dizzy
Highway friendly rear gear of 2.73:1 (nothing like getting mileage in the teens out of a 440).
The two questions I have are:
1) Should I go with the steel shim gasket to get compression up to about 9.1:1, and
2) What converter should I use?
It is a beater but it won 1st place in the Georgia Tech car show last year in the student beaters category ... so show some respect!!
Thanks in advance for your
So pretty!
