Re: 70's 340 T/A heads
[Re: jagrunt551]
#520477
11/09/09 12:41 PM
11/09/09 12:41 PM
Posts: 4,799 ILL
MLR426
ILL
Did all the heads come with offset push rod holes and rocker arm assemblies or did some come through with the stock push rod holes , using the stock rocker arm assemblies? Thanks
As far as I know all T/A motors were made with off set ductile rocker arms assemblies and heads with off set push rod holes. You must have came across the other 915 small block head casting with out off set push rod holes ?
logan426
[Re: aarcuda]
#520480
11/09/09 02:35 PM
11/09/09 02:35 PM
Posts: 210 Denmark, Helsingor
AAR70
Denmark, Helsingor
What abut the U casting beside the spark plugs, does the U casting mean TA heads?
[Re: AAR70]
#520481
11/09/09 03:31 PM
11/09/09 03:31 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have a set of non-T/A 915's they have the U cast in so obviously you can't use that... Look at the pushrod hole location only....
There are small valve 915's, large valve 915's & T/A 915's....
[Re: 1_WILD_RT]
#520482
11/09/09 04:37 PM
11/09/09 04:37 PM
Posts: 15,491 the boonies
aarcuda
the boonies
pushrod location is the only distinguishing feature
