New best in the 63 Plymouth w/Indy 440-25 epoxy inserts
#520278
11/09/09 09:07 AM
11/09/09 09:07 AM
63 plymouth was going 10.21 with just indy 440-25 crossram in same air. i added the indy epoxy inserts and off the trailer 1st a 10.13, then i short shifted to 6000-6100 and it goes 10.04. put in the new converter and goes 9.978. car is 3856 lbs. air was 500+ DA,same as the last few times out.so in my application they do work.
Re: New best in the 63 Plymouth w/Indy 440-25 epoxy inserts
#520279
11/09/09 09:16 AM
11/09/09 09:16 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
What heads are on the car Chris.. -1 ? congrats,,,nice improvement,,, dumb question....what do the epoxy inserts do ?
#520280
11/09/09 11:11 AM
11/09/09 11:11 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
So the inserts gained around 0.08.... I can believe that, good job.
Russ
[Re: max_maniac]
#520281
11/09/09 09:10 PM
11/09/09 09:10 PM
Russ
Russ 10.21 to 10.04 is .17 shifting it pretty much the same. ihave shifted the car before around 6000, once in a while shifting it a little higher due to missing the pushbuttons.air DA was a litle worse sunday compared to the 10.21 pass. going out this weekend to try another 9 second pass. hope air is good or better.
#520283
11/09/09 09:33 PM
11/09/09 09:33 PM
max_maniac
Aurora, Oh.
63 plymouth was going 10.21 with just indy 440-25 crossram in same air. i added the indy epoxy inserts and off the trailer 1st a 10.13, then i short shifted to 6000-6100 and it goes 10.04 . put in the new converter and goes 9.978. car is 3856 lbs. air was 500+ DA,same as the last few times out.so in my application they do work.
Russ
10.21 to 10.13 is .08 ---- then you made other changes. So changing your shift points AND your converter had nothing to do with it? Interesting to say the least So the converter was a waste of time and $$$.
Russ
[Re: max_maniac]
#520284
11/09/09 09:43 PM
11/09/09 09:43 PM
Russ
Russ
RUSS,i have short shifted the car before with no gains. last pass was 9.97 with new converter. 10.21-10.04 is the true gains with just inserts.
[Re: 69CHARGERMD]
#520285
11/09/09 10:47 PM
11/09/09 10:47 PM
They are supposed to make the intake more like a tunnel ram in a way. It is Supposed to help with puddling of fuel inside the intake. We did back to back tests with them at Norwalk and our gains were different, but maybe it varies with each car.
Casey
#520286
11/09/09 10:52 PM
11/09/09 10:52 PM
#520287
11/09/09 11:01 PM
11/09/09 11:01 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Casey
Results might have slight variations
[Re: hemi-itis]
#520289
11/10/09 01:39 AM
11/10/09 01:39 AM
Casey
.... ok.... not sure what your getting at.
Congrats on the 9 second pass if thats what your looking for.
Im just not too convinced that the inserts caused it to speed up. nice fall air. different shifting. converter. Im just not buyin the inserts had that much affect, but I could be wrong. I no what our gains were and I know that the inserts won't be in there next year
But good job chris, glad you finally went a 9 in that car
Casey
[Re: 383man]
#520291
11/10/09 07:21 AM
11/10/09 07:21 AM
Nice going Chris and congrats on the 9 second pass in such a good looking car. Maybe I should think about that intake on my next eng. Is that the Max Wedge size ports ?? Ron
RON, they are 440-1 heads with max wedge size ports, if your looking for a correct max wedege look, its not for you but if you want to make power and get every ounce of hp from your combo then yes the 440-25 intake for you. it killed me to change drom a original crossram on this car but i'm a et junkie and want every ounce of power i can get. hope you go for it, your car is killer.
#520292
11/14/09 06:21 PM
11/14/09 06:21 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thank you Chris. Ron
[Re: 383man]
#520293
11/14/09 07:00 PM
11/14/09 07:00 PM
RON, a dual carb intake on your car would be so awesome. you got a beautiful car there. i love all your improvements you have done to it this year.
#520294
11/14/09 07:52 PM
11/14/09 07:52 PM
Posts: 1,401 Wi.
old_racer
Wi.
Hi Guys, I totally agree Ron's car looks great, Chris your running great, Ron needs and intake and Chris just took one off Humm, I think Chris should make Ron a deal and help him out with and intake to get him into the real max wedge look and play let's make a deal! and you guy are both out on the east coast. Just a thought. Russ
[Re: old_racer]
#520295
11/14/09 08:12 PM
11/14/09 08:12 PM
Russ, i got 3 of them on the shelf with matching carter carbs, whenever he's ready i'll make him a deal of a lifetime.he'll need some max wedge ports though. racers help racers.
#520296
11/15/09 03:25 AM
11/15/09 03:25 AM
383man
Balt. Md
I appreciate that Chris. Hopefully after the holidays this year I can have the cash to talk with you about a crossram setup. I want to start building my next eng as soon as I can afford the parts. I am still thinking on CNC'd Eddy heads on the next eng I build for my 63. And thanks Old racer for the kind words. Ron
