Leaf Springs on 1973 Cuda #519707
11/08/09 06:34 PM
11/08/09 06:34 PM
Iowa
FRCUDA Offline OP
FRCUDA  Offline OP
Iowa
While removing the leaf springs on my 1973 Cuda the bolt which comes through the springs from the axle housing broke off. Does anyone know how this can be repaired?
Re: Leaf Springs on 1973 Cuda [Re: FRCUDA] #519708
11/08/09 07:12 PM
11/08/09 07:12 PM
ohio
CumminsExpress Offline
ohio
find a local spring shop they should have the bolts
Re: Leaf Springs on 1973 Cuda [Re: FRCUDA] #519709
11/09/09 07:56 PM
11/09/09 07:56 PM
Iowa
FRCUDA Offline OP
FRCUDA  Offline OP
Iowa
How do I remove the bolt from the axle housing?
Re: Leaf Springs on 1973 Cuda [Re: FRCUDA] #519710
11/10/09 08:05 PM
11/10/09 08:05 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The locating pin should actually be part of the leaf spring....The rear housing perches have a hole for the pin to give the housing a secure and correct location on the spring...
