Shifter cable routing #519035
11/08/09 09:42 AM
11/08/09 09:42 AM
Whitinsville Ma
superbee500 Offline OP
Whitinsville Ma
Ive had a B&M Quarter stick in my car for years. I ran the cable down the passenger side of the trans and around the front worked great. Now I moved the shifter back and up on a pedestal and i cant seam to make it work with a really long cable. Have any of you run the cable on the driver side with out header issues? Its a 69 B body with a low deck and 2" super comp headers
Kevin
69 superbee 04 ram 3500
Re: Shifter cable routing [Re: superbee500] #519036
11/08/09 10:25 AM
11/08/09 10:25 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
The loop from pass side to driver side works best unless you can get/make a rear exit shifter bracket. I may make one for my Barracuda this winter. I am not sure what lenght cable I have (5')?
It has been like that for years, but the bend looks like it is tighter going into the bracket that holds the cable to the pan. Don
