Re: has anyone had problems with electric fans
[Re: daves72dart]
#518978
11/08/09 08:56 AM
11/08/09 08:56 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I have. I went from a junk Zirgo 16" puller, to a chevy HHR fan, with built in shroud, and it seems to have helped alot. And for 65 dollars, I'd say it's the best bang for the buck as far as fans are concerned. codfish
[Re: daves72dart]
#518979
11/08/09 09:16 AM
11/08/09 09:16 AM
Challenger 1
Cincinnati, Ohio
has anyone had problems with over heating with electric fans? i will be runing a electric waterpump too.this will be a street/strip car.thanks
Yes many people have.
[Re: ahy]
#518986
11/12/09 10:43 PM
11/12/09 10:43 PM
Challenger 1
Cincinnati, Ohio
No problems for me... running a MP clutch fan and HV water pump w. anti-cavitation plate slightly overdriven. Cools like a charm.
[Re: codfish]
#518989
11/13/09 11:16 AM
11/13/09 11:16 AM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
I have.
My exact scenario. I hated that as you say "JUNK" zirgo. My HHR setup is one of the best things I have ever done.
[Re: RonP]
#518990
11/13/09 11:23 AM
11/13/09 11:23 AM
quick77rt
Parts Problem
Parts Problem
Im using a dual pass rad, with dual hd spal puller fans in there al shroud, and a crs pump, one fans hooked to a stat, but both can be manual.
At 13.1 Ive never had anything close to overheating, if anything its easy to make it run too cool.
I feel the dual pass rad has alot to do with it.
Pump, rad, fans, noids, ect was about a grand, alot, but its a complete cooling system that works.
Good luck.
[Re: quick77rt ]
#518992
11/13/09 11:46 AM
11/13/09 11:46 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
I am going to switch to that HHR fan next year. I have a stock size 26" aluminum radiator. Anybody know which part number will fit the best? Thanks for the advise.. Thanks a ton!!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#518993
11/13/09 12:42 PM
11/13/09 12:42 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Actually, the HHR fan fits a 22" rad. better.
