904 question #518416
11/07/09 06:45 PM
11/07/09 06:45 PM
ohio
dart70 Offline OP
dart70  Offline OP
ohio
When installing a reverse manual valve body (turbo action), does anything have to be done to the governor assembly? Does anyone make a spacer to replace it or could the governor body just be gutted out and reinstalled. Will this cause an oiling issue?
Re: 904 question [Re: dart70] #518417
11/07/09 07:37 PM
11/07/09 07:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If I remember correctly, I don't believe there is any oil going to the govenor after the RMVB is installed, so you could just gut it, I made a spacer to fill in for the govenor housing on mine, any local machine shop could make one easy enough, all it does is keep the parking pawl in location.
Re: 904 question [Re: dartman366] #518418
11/07/09 07:48 PM
11/07/09 07:48 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The governor is not required with a manual valve
body. It can be left or removed. A&A Transmission
has spacers to replace it.
Pat #12680SP
317-831-3066
Re: 904 question [Re: S/ST 3040] #518419
11/08/09 01:31 PM
11/08/09 01:31 PM
ohio
dart70 Offline OP
dart70  Offline OP
ohio
If that is the case, then are the sealing rings from the governor housing (parking pawl) to output shaft support necessary anymore?
Re: 904 question [Re: dart70] #518420
11/08/09 02:52 PM
11/08/09 02:52 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
probably not but i am not sure if they seal to a passage in the rear support, I left mine in as it won't hurt to have them there even if there is no oil at that point, but then again the inner ring may seal the center dia which if I remember correct is fed oil from the system and may bleed past.
Re: 904 question [Re: dart70] #518421
11/08/09 07:14 PM
11/08/09 07:14 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
That is the lubrication circuit return oil from the cooler. Leave those ring(s)(depending on roller output support useage) off, and see what happens.
