Re: F.A.S.T. Polyglass tire pressures?
[Re: DJVCuda]
#517444
11/06/09 01:15 PM
11/06/09 01:15 PM
Posts: 276 NY
aarmaniac
NY
We check the foot print and adjust the pressure to get the most rubber on the ground. about 24 pounds is normal with our G60-15's.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
[Re: aarmaniac]
#517445
11/06/09 01:52 PM
11/06/09 01:52 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
There really is no rule of thumb. Find somebody with a similar car and start with what they got.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: BSB67]
#517447
11/06/09 09:56 PM
11/06/09 09:56 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i am not sure if this still applies... but ..i used to drive them with low pressue to loosen up the sidewalls.. put maybe 4-5 slow miles..around the neighbor hood. then do the air pressure to get the best contact patch routine.. fwiw.. chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#517448
11/07/09 06:54 AM
11/07/09 06:54 AM
Posts: 518 ny
greenmcode
ny
I run 45 in the fronts 35 rear.. Best 60' 1.75.. [image] ![](http://i55.photobucket.com/albums/g153/fata12/DSC_39321.jpg) [/image]
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
