Torsion bar bolt ,loosen or tighten to raise vehicle? #516915
11/05/09 06:58 PM
11/05/09 06:58 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
When raising the front end height of my vehicle do I turn the adjusting bolt clockwise or counter clockwise?
Re: Torsion bar bolt ,loosen or tighten to raise vehicle? [Re: 74RR] #516916
11/05/09 07:02 PM
11/05/09 07:02 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
clockwise will raise the car, counter clockwise will lower it,...
Re: Torsion bar bolt ,loosen or tighten to raise vehicle? [Re: B1Frank] #516917
11/05/09 08:44 PM
11/05/09 08:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
One full turn gains you about a 1/4 to 3/8". If you jack the weight off the front it makes it a lot easier to crank it up.
Re: Torsion bar bolt ,loosen or tighten to raise vehicle? [Re: 74RR] #516918
11/05/09 08:47 PM
11/05/09 08:47 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
don't forget to align the vehicle when you are done. your tires will appreciate it if you do.
DRIVE EM, DONT HIDE EM.
Re: Torsion bar bolt ,loosen or tighten to raise vehicle? [Re: 74RR] #516919
11/06/09 08:56 AM
11/06/09 08:56 AM
74RR Offline OP
74RR  Offline OP
Thanks guy's for the reply's!!!
Re: Torsion bar bolt ,loosen or tighten to raise vehicl [Re: 74RR] #516920
11/06/09 08:36 PM
11/06/09 08:36 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
3/4 socket will do it
Re: Torsion bar bolt ,loosen or tighten to raise vehicle? [Re: 74RR] #516921
11/07/09 07:43 PM
11/07/09 07:43 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...if you change the height an alignment is probably a good idea.
be careful...raising will reduce your caster and you need a degree or 2 for hi speed stability.
loosen and re-tighten your lower control arms if you have rubber bushings..they are vulcanised to the sleeve and provide some of your suspension.
not req'd with the plastic styles as they basically just take up space...
...al
Re: Torsion bar bolt ,loosen or tighten to raise vehicl [Re: 74RR] #516922
11/09/09 02:28 AM
11/09/09 02:28 AM
Clockwise will raise the car, counter clockwise will lower it.Thanks
HID Light
