Milling off top of dome pisons?
#516817
11/05/09 05:53 PM
11/05/09 05:53 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
I have MP Pistons I would like to use PN 3690834 they are 0.030 over raised dome pistons and according to MP 11.5:1 compression, probably calculated with 88cc heads,
Is it ok to mill off the top of the dome to lower the compression to 10.5-10.75:1 and can you figure out how much would be needed to mill off?
Thordur Ingvarsson, Reykjavik Iceland
1970 Dodge Challenger R/T 440 sixpack Shaker(sold)
1971 Plymouth Cuda pro-street project
2007 YAMAHA YZF R1 189 HP
2007 YAMAHA FZ1 SA 150 HP
2003 Mercedes Benz E-200 Kompressor 163 HP
toti62@internet.is
Re: Milling off top of dome pisons?
[Re: 70rtshaker]
#516819
11/05/09 06:21 PM
11/05/09 06:21 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before milling the dome, look inside the piston to see if there is a depression that matches the shape of the dome. If there is, it would be wise to measure the depth of the depression and compare it to the dome extension to see what the actual thickness is.
[Re: John_Kunkel]
#516820
11/05/09 07:26 PM
11/05/09 07:26 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
The inside bottom of the piston is not depressed according to dome just flat bottom.
If anyone have these old DC or MP catalogs with these pistons, the numbers specs would be very much apreciated. Thnks
toti62@internet.is
[Re: 70rtshaker]
#516822
11/05/09 08:08 PM
11/05/09 08:08 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Are they the old TRW forgings? If so no need to mill them (unless the small dome is a problem) w/88cc cyl hd they should be about 10.7 or less with undecked block.IIRC they called for the piston to be below the deck -.020 and depending on cc of the heads were anywhere from 10.7 t0 13.5. Need to check the deck height.
Leave the gun.......take the Cannoli's....Mike
