Re: HARD START AFTER SETTING A COUPLE OF DAYS??
[Re: groundpoint6]
#516520
11/05/09 01:10 PM
11/05/09 01:10 PM
Posts: 1,443 Maryland
Dads426
Maryland
Our Challenger does it with a Holley carb if sitting more than a week (fuel bowl is larger). When we had the thermoquad on it, the fuel would evaporate after a few days. I have a small funnel that fits on the primary vent of the holley and I just pour a small cup of fuel in the primary bowl and it starts right up.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: moparjohn]
#516521
11/05/09 01:12 PM
11/05/09 01:12 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
I have the exact same problem with my newly-rebuilt 383 and Holley. Runs great after started, but takes a lot of cranking to get it there...
Until total honesty is on the table, we're not even talking about reality...
[Re: Iceman01]
#516522
11/05/09 01:53 PM
11/05/09 01:53 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
With the Holley style carbs having the air vent on top of the bowls, is there a chance that when the carb sits for lets say a week or two, and the bowl vent is open to the air coming in thru the air cleaner assembly, would the fuel in the bowl become "stagnet" or less flammable causing the starting issues?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: moparjohn]
#516524
11/05/09 04:31 PM
11/05/09 04:31 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
I had experienced similar hard starting after prolonged periods of time with my recently completed six-pack (new carbs). I have a fully functional choke set correctly, overnight or a couple of days, starts up cold perfectly. Sits a week or longer, behaved as though there were no fuel in the bowls. Went so far as to pull the center carb off, filled the bowl and let it sit on bench stand expecting to see leakage, didn’t find it. I had converted over to an electric fuel pump system anyway, pretty easy to wire up a “prime” button to manually run the pump for a few seconds prior to start up. Now it fires right up no matter how long it’s been sitting, if it’s been primed. I’m convinced the fuel is simply evaporating out of the bowls. I don’t recall having starting problems like this back in the day, running original mechanical fuel pumps on these cars. I have read today’s gasoline formulation makes for much faster evaporation rates. Then again, my cars then were daily drivers and never sat around long.
[Re: moparjohn]
#516525
11/05/09 05:57 PM
11/05/09 05:57 PM
RapidRobert
I'd add the ~1/2" thick 4bbl spacer that felpro sells between the carb/intake & block the heat riser. As said heat soak evaporates todays gas FAST. I'd take off the air cleaner before starting just one time & if pulling on the throttle gives no/little AP squirt something will need to be changed.
[Re: moparjohn]
#516527
11/07/09 09:45 AM
11/07/09 09:45 AM
Posts: 5,270 Missouri
MY340
Missouri
In NW Indiana you definitely need to use a choke for easier cold starts. If the car sits for extended period of time you may have to let it crank over a few times first to fill the bowls. Then give it a few pumps and make sure the choke is closed. My Duster with a 750 Eddy/manual choke starts well with this method and if it's just a few days all I do is close the choke give it a few pumps and it fires right up. My old SpaceDuster 340 was a bear to start in cool weather/extended periods with a chokeless TQ.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
