Using Armaflex as an Interior Insulation #516016
11/04/09 04:17 PM
11/04/09 04:17 PM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
Has anybody tried using a product called Armaflex to insulate the inside of their car? It is used in the HVAC industry as pipe insulation. It can be bought in sheets from 1/4" to 1" thick. It is glued with contact cement. It is a closed cell rubber product.The price is low, especially compared to some of these other products like Dynamat or others. Just wondered if anyone could say it's good or bad for this use.
No Stock
Re: Using Armaflex as an Interior Insulation [Re: bfury] #516017
11/07/09 09:46 AM
11/07/09 09:46 AM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
I was just at Lowes looking at insulation for HVAC, was going to use it for headliner, floor and firewall. Came in rolls 16" wide I think, 1/4" thick and adhesive on the back for $15. R value was only 3, but I thought it would be good enough and help deaden some road noise and rattles.
Re: Using Armaflex as an Interior Insulation [Re: 49wayfarer] #516018
11/09/09 03:32 PM
11/09/09 03:32 PM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
This stuff is as cheap but far denser and it is closed cell. Easy to work with. I have seen the stuff at the Home Centers too but this will work way better. Thanks for the reply.
No Stock
Re: Using Armaflex as an Interior Insulation [Re: bfury] #516019
11/10/09 11:40 PM
11/10/09 11:40 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Yes, been using it since the 60s. You can see it in the trunk of my coupe. It is designed for refrigeration but is also used as a sound deadener on pipes and air ducts.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516020
11/12/09 02:19 AM
11/12/09 02:19 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
where can you purchase this armaflex ???
thanks in advance
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Using Armaflex as an Interior Insulation [Re: fstfish66] #516021
11/12/09 09:44 PM
11/12/09 09:44 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
You can purchase it at any insulation company or insulation distributor. We use Armstrong 520 glue to nail it down. If you know a pipe insulator they are pretty good at this (30 years). When I get back home I'll be doing the interior floorboards too.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516022
11/13/09 04:07 AM
11/13/09 04:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
if you get the chance some pics of the material in place would be great,,,i hope to soon insulate my 66 from heat and sound,,,thanks
2015 cherokee
2013 R/T classic
Re: Using Armaflex as an Interior Insulation [Re: fstfish66] #516023
12/07/09 12:45 AM
12/07/09 12:45 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Started on the armaflex interior today. I've only been out of the field for a year and already I'm rusty. Started with the harder areas like the tunnel. 1/2 inch thick armaflex and 520 glue. A very sharp knife.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516024
12/07/09 12:51 AM
12/07/09 12:51 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Then tackled the firewall. Lots of little pieces here, take your time.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516025
12/14/09 12:46 AM
12/14/09 12:46 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
What the heck did I do all weekend. Well some of this and some of that.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516026
12/14/09 12:54 AM
12/14/09 12:54 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Of course everything went perfect until I went to mount the console. The thickness of the insulation would not let the mounts line up anymore. So I drew a chalk line along the console and trimmed the insulation along the line, glued the carpet back, and remounted the console. Okay one or two bad words might have slipped out.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516027
12/14/09 01:01 AM
12/14/09 01:01 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Hooked up the gauges and mounted the dash. Next I need to insulate between the trunk bulkhead and interior rear wall.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516028
12/14/09 09:22 PM
12/14/09 09:22 PM
moparx Offline
moparx  Offline
lookin good ! nothing like a sucessfull weekend to stay motivated !
Re: Using Armaflex as an Interior Insulation [Re: moparx] #516029
12/15/09 01:29 AM
12/15/09 01:29 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nice loking job,,,, i hope i remember this topic when i insulate my cuda,,,
2015 cherokee
2013 R/T classic
Re: Using Armaflex as an Interior Insulation [Re: fstfish66] #516030
12/21/09 10:33 AM
12/21/09 10:33 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Started on the rear bulkhead area.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516031
12/21/09 10:37 AM
12/21/09 10:37 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
This is where your age starts to show up a bit. I am sore today from reaching through that access hole all day.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516032
12/21/09 10:44 AM
12/21/09 10:44 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
I still have a little more to do in there, but if you want it done right, you have to hire a real insulator. It's pretty easy to find one that will work for food and beer.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516033
01/10/10 11:23 PM
01/10/10 11:23 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Finished the floorboards with armaflex.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516034
01/10/10 11:26 PM
01/10/10 11:26 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Even did inside the doors.
Re: Using Armaflex as an Interior Insulation [Re: RAT PATROL] #516035
02/19/10 11:28 PM
02/19/10 11:28 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Does it still contain asbestos?
Mesothelioma - products containing asbestos...
