T & C 3.8 liter dripping oil #516008
11/04/09 03:55 PM
11/04/09 03:55 PM
central PA
mopartial Offline OP
central PA
05 minivan dripping too much oil. 150K mi. Drip is hanging from bottom of oil filter, but I cant see where its coming from. So I changed oil and filter, wiped everything clean. Snugged oil pan bolts which werent loose at all. Next day, drip, drip, drip...
Looks like I could replace oil pan gasket. Are these prone to leaking there or where else to look?
Tanks.
If it aint broke, dont break it.
Re: T & C 3.8 liter dripping oil [Re: mopartial] #516009
11/04/09 04:15 PM
11/04/09 04:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Look at the op switch.Ive seen them just barely leak.Never had any real problem with the pans.Rocky
Chrysler Firepower
Re: T & C 3.8 liter dripping oil [Re: therocks] #516010
11/06/09 02:18 PM
11/06/09 02:18 PM
central PA
central PA
Pardon my ignorance, whats an op switch and where is it located?
Thanks Rocky
Re: T & C 3.8 liter dripping oil [Re: mopartial] #516011
11/06/09 02:22 PM
11/06/09 02:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil pressure switch.
Re: T & C 3.8 liter dripping oil [Re: mopartial] #516012
11/06/09 03:18 PM
11/06/09 03:18 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
Thanks Rocky
The OP Oil pressure sending unit is right next to the oil filter they can often leak into the wire conector and drip out on the ground.
Kevin
