71 Cuda' - Tank within a tank? #515860
11/04/09 11:24 AM
11/04/09 11:24 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I'm cleaning up the original gas tank from my 71' Cuda, and on the top there is a sticker that is similar in color (yellow) font, etc to the core support sticker. It says something to the effect of there being a tank, within the tank, and to pull out a plug to drain it. I don't remember the exact wording- the car is a CA car- so I'm assuming that it has to do with CA emissions? It is nearly perfect condition. I have never heard anyone mention this before. ??????????????
Re: 71 Cuda' - Tank within a tank? [Re: Kirby] #515861
11/04/09 02:09 PM
11/04/09 02:09 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Drain for expansion tank. All states.
Re: 71 Cuda' - Tank within a tank? [Re: Snoopy] #515862
11/04/09 02:19 PM
11/04/09 02:19 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thats the one. News to me-
Re: 71 Cuda' - Tank within a tank? [Re: Snoopy] #515863
11/04/09 02:20 PM
11/04/09 02:20 PM
Snoopy Offline
Snoopy  Offline
This shows the internal tank.
Re: 71 Cuda' - Tank within a tank? [Re: Snoopy] #515864
11/04/09 02:27 PM
11/04/09 02:27 PM
Snoopy Offline
Snoopy  Offline
From 70 FSM
Re: 71 Cuda' - Tank within a tank? [Re: Snoopy] #515865
11/04/09 03:17 PM
11/04/09 03:17 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Cool Snoopy. Does that mean I have to hook all the lines back up again? I'm running an electric fuel pump and return lines now-actually not til spring.
Re: 71 Cuda' - Tank within a tank? [Re: Kirby] #515866
11/05/09 12:12 AM
11/05/09 12:12 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have the same stock tank & lines in my 1970 'Cuda, but pulled it out to install a larger capacity tank for a while with larger fuel inlets, outlets & vents etc.
How did you plumb the return lines? Did you use the two-bung on the fuel sending unit? Are you leaving the rest of the system in place?
Re: 71 Cuda' - Tank within a tank? [Re: jbc426] #515867
11/05/09 12:16 AM
11/05/09 12:16 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Pick-up lines & sending unit...
Re: 71 Cuda' - Tank within a tank? [Re: jbc426] #515868
11/05/09 12:21 AM
11/05/09 12:21 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Return, transfer and vent lines.
Point is, I documented and removed the stock stuff and safely tucked it away until I'm ready to turn the car into a museum piece some day.
It just didn't make enough power for my tastes in stock form, and I didn't want to hack up the stock stuff. These mods are all bolt in, and the parts you have are pretty rare, California ECS stuff.
