Re: 70 Roadrunner
[Re: JohnRR]
#515220
11/03/09 02:28 PM
11/03/09 02:28 PM
Posts: 3,544 Lansing, MI
70gtx440dana
Lansing, MI
The last 8 digits of the vin should be stamped a the pan rail ex: 0A123456. These should match the VIN of the car. The top pad of the engine will have numbers similar to F 440 1 22 HP. The stamp/assembly date will likely be within a few weeks prior to the SPD of the car. So in this case you are probably looking for a stamp date between 1 22 & 2 15. Please note that these comments are general and should not be assumed to be correct all of the time. I have a 70 440 car with a SPD date of 2/27/70 the stamp date on the engine is 2 9. I hope this helps!!!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Roadrunner
[Re: 6pkRB]
#515223
11/04/09 03:37 PM
11/04/09 03:37 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Partial VIN is stamped on the trunk lip and rad support just like the engine. In my case its 0AXXXXXX with the XXXXXX = the sequential serial number.
You've gotten some very good answers to your questions so far.
My advice would be to check the VIN 1st (making sure it looks unaltered with the correct rosette rivits).
Then check the fender tag to make sure it matches; post a pic here to determine it's originality and to help with a decode.
Check for the partial VIN on the trunk lip and the rad support. Trunk lip one is likely under the weatherstripping and the rad one might be between the rad and the support so take tools!
Check the door sticker just to confirm (if it's still there)
Check the motor for the correct stamp (HP or HP2) along with an appropriate assy date. Again post pics if you want confirmation that it looks unmessed with. Check the pan rail for the partial VIN....again with the pics.
...unless you have access to the BS, that should about do it.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 70 Roadrunner
[Re: 6pkRB]
#515224
11/04/09 04:21 PM
11/04/09 04:21 PM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
Thanks for the advise. I probably need to stick with what I know about A12 cars. Anyway do the 70 440 6pk runners have the vin stamped on the radiator support and trunk lip like the 69 1/2 cars?
If you think you know about 69.5 A12 cars then I'm confused why you asked the question the way you did ...
Re: 70 Roadrunner
[Re: 6pkRB]
#515226
11/06/09 08:55 AM
11/06/09 08:55 AM
JohnRR
A gulag near you.
Thanks everyone for the helpful comments.
Johnahah, thanks for yours too, but wasn't much help, so why waste your time?
Well what would you expect for such an ODD question ?
