Challenger Electrical issues anyone in LA that you ? #514215
11/02/09 01:40 PM
11/02/09 01:40 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
i need some help with my 70 Challenger and its electrical issues. The windshield wipers dont go seem to work , the interior lights dont turn on . Anyone in Los Angeles that knows these cars and will fix electrical porblems? Thanks
Chris
Re: Challenger Electrical issues anyone in LA that you ? [Re: ChrisD] #514216
11/02/09 04:09 PM
11/02/09 04:09 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Gety a test light and post in Questions and Answers
Re: Challenger Electrical issues anyone in LA that you ? [Re: ChrisD] #514217
11/02/09 04:37 PM
11/02/09 04:37 PM
I'd check your fuses which I'm sure you've done & pull the connector off of the wiper switch behind the dash & see if it has fire to it (when the ign sw is switched "on") & pull apart the black bulkhead connectors on the firewall & check/clean the brass terminals(they do come out) & might jump fire to the wiper motor itself to see if it is functioning. Pull the connector off of the light switch & jump fire to the terminal for the interior lights. These test will help you pin down the open & give you the confidence to continue your search. www.mymopar.com has wiring diagrams for your chally. Sears has cheap digital VOM's for under 10 bucks & sometimes as said a 3 dollar test light works good also. Happy hunting and any more Q's dont hesitate to holler.
