Re: RE:727 Trans....Blanket or Shield?
[Re: J_BODY]
#514176
11/02/09 11:00 PM
11/02/09 11:00 PM
Posts: 3,031 Sac, CA
mopowers
Sac, CA
My dad and I both run the Lofgren blanket. Fits great in both cars and there is no fricken way they would "aid" in heating a trans up. They cover the critical area of the torqueflight and they have been proven to work. I haven't talked to Chuck in a long time. It would be a bummer if he wasn't having the blankets made any longer.
Do you drive the cars on the street? Just curious because I plan on using one and am worried it'll keep too much heat in the trans.
[Re: beepbeepdon]
#514181
11/03/09 07:18 PM
11/03/09 07:18 PM
Posts: 257 madison, ohio
modified1090
madison, ohio
i'm not 100% sure who made it. i can look at the sfi tag when i get the car put away this weekend for now the best i could find was at jegs jegs the shield is only modified on the bottom plate up front for the drain plug i also have a deep pan. and the ears have been cut off the trans.
[Re: modified1090]
#514182
11/03/09 08:16 PM
11/03/09 08:16 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I originally had a blanket but on the street it was a big pain keeping the straps off of the headers,you had to have the middle one just right so it did not interfere with the shifter arm (turbo action). I went to a CSR shield, you have to trim the transmission tabs but in my 67 Coronet there were no tunnel modifications needed.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 540dust]
#514184
11/03/09 08:58 PM
11/03/09 08:58 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
This should be taken into consideration.
thanks for reminding me i am planning to use the old blanket on the inside of the car and the new on the trans.
[Re: smokinwoody]
#514188
11/04/09 07:37 AM
11/04/09 07:37 AM
Posts: 13,608 Marion, South Carolina [><]
an8sec70cuda
smokinwoody...Mine had a stock drum. Has an A&A billet steel drum in it now. CHIP
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
