Re: RE:727 Trans....Blanket or Shield? [Re: J_BODY] #514176
11/02/09 11:00 PM
11/02/09 11:00 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
My dad and I both run the Lofgren blanket. Fits great in both cars and there is no fricken way they would "aid" in heating a trans up. They cover the critical area of the torqueflight and they have been proven to work. I haven't talked to Chuck in a long time. It would be a bummer if he wasn't having the blankets made any longer.
Do you drive the cars on the street? Just curious because I plan on using one and am worried it'll keep too much heat in the trans.
Re: RE:727 Trans....Blanket or Shield? [Re: mopowers] #514177
11/02/09 11:11 PM
11/02/09 11:11 PM
Saskatchewan, Canada
barracudabob Offline
Lofgren isn't producing them anymore. I phoned this summer, and was told they quit selling them.
Re: 727 Trans....Blanket or Shield? [Re: beepbeepdon] #514178
11/03/09 02:52 AM
11/03/09 02:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The CSR shield is nice, but is very tight to the trans tunnel in the firewall area. I gave up trying to get it to fit for now. you also have to cut off the "ears" on the front of the trams bellhousing along with the boss that holds the piviot rod on the three piece kickdown.
Re: 727 Trans....Blanket or Shield? [Re: 451Mopar] #514179
11/03/09 05:57 AM
11/03/09 05:57 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
The CSR carbon shield is nice but a total nightmare to install in a 73 DartSport a few years ago. On my current car I went with an SFI approved JW Ultrabell on my 727 and a Lofgren blanket, very easy to install.
Re: 727 Trans....Blanket or Shield? [Re: ProSport] #514180
11/03/09 09:57 AM
11/03/09 09:57 AM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
CSR shield here.
Re: RE:727 Trans....Blanket or Shield? [Re: beepbeepdon] #514181
11/03/09 07:18 PM
11/03/09 07:18 PM
madison, ohio
modified1090 Offline
madison, ohio
i'm not 100% sure who made it. i can look at the sfi tag when i get the car put away this weekend
for now the best i could find was at jegs
jegs
the shield is only modified on the bottom plate up front for the drain plug i also have a deep pan. and the ears have been cut off the trans.
Re: RE:727 Trans....Blanket or Shield? [Re: modified1090] #514182
11/03/09 08:16 PM
11/03/09 08:16 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I originally had a blanket but on the street it was a big pain keeping the straps off of the headers,you had to have the middle one just right so it did not interfere with the shifter arm (turbo action). I went to a CSR shield, you have to trim the transmission tabs but in my 67 Coronet there were no tunnel modifications needed.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: RE:727 Trans....Blanket or Shield? [Re: 67HEMI] #514183
11/03/09 08:52 PM
11/03/09 08:52 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
This should be taken into consideration.
Re: RE:727 Trans....Blanket or Shield? [Re: 540dust] #514184
11/03/09 08:58 PM
11/03/09 08:58 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
thanks for reminding me i am planning to use the old blanket on the inside of the car and the new on the trans.
Re: RE:727 Trans....Blanket or Shield? [Re: blownzoom440] #514185
11/03/09 09:23 PM
11/03/09 09:23 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well here is a pic of my trans. move the foor boards 2 " and a pic of what it did to the blanket.
Re: RE:727 Trans....Blanket or Shield? [Re: VernMotor] #514186
11/03/09 11:51 PM
11/03/09 11:51 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Never woulda beleived the blanket would take that kind of explosion with that little damage on the blanket. WOW.
Sure makes me feel a lot better in having a blanket on mine now.
Re: RE:727 Trans....Blanket or Shield? [Re: superwrench] #514187
11/04/09 07:31 AM
11/04/09 07:31 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
question...on some of those explosions, how many are using stock componants...like drums,sprags, pumps, etc...
I use the CSR shield but my trans that was built by CRT also has all the beefed up race componants..theres nothing left stock except the case..
Re: RE:727 Trans....Blanket or Shield? [Re: smokinwoody] #514188
11/04/09 07:37 AM
11/04/09 07:37 AM
an8sec70cuda Offline
smokinwoody...Mine had a stock drum. Has an A&A billet steel drum in it now. CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: RE:727 Trans....Blanket or Shield? [Re: an8sec70cuda] #514189
11/04/09 08:56 AM
11/04/09 08:56 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
My was a stock drum...been in there for 20 years. car broke the rearend about 5-6 ft off the line.will have a good drum in it next time around
