Re: t/a with dana 60 issue
[Re: kingkt]
#513623
11/01/09 09:54 PM
11/01/09 09:54 PM
Posts: 862 Doo-Dah, KS
440fied
Doo-Dah, KS
you need a 7260 to 7290 conversion u-joint available at o'reilly's, auto zone, napa etc... From Greg Lewallen's guide to the 8 3/4, alot of this info works for Dana 60's Quote:
The 8-3/4" axle was offered with two size cross & roller style universal joint. These are referred to as the '7260' (2-1/8" yoke ID) and the '7290' (2-5/8" yoke ID). Most Imperials and some C-bodies used a different univer- sal joint. The '1330' type joint was used on Imperials and others with a constant velocity joint. The '1330' uses outside snap rings instead of the inside snap rings used by the '7269' and '7290'. The cap diameter for the '7260' is 1.078". The cap diameter for the '7290' is 1.126". The '1330' style joint cap diameter is 1.063".
Moog (Precision) part # for conversion joint is 347
TRW (Federal-mogul) part # for conversion joint is 20226
[Re: Alaskan_TA]
#513627
11/01/09 10:53 PM
11/01/09 10:53 PM
Posts: 6,435 Abilene, Texas
fastmark
Abilene, Texas
I am not familiar with dana rear ends at all, but if it helps any....
T/A driveshafts have a small u-joint in front & big one in the rear.
I hate to seem stupid here, but I have never seen a drive shaft with two different size joints. I have never owned a T/A but I have had an AAR since 76 and the driveshaft it in has both ends the same. I was an auto and I changed it to a 4 speed. I'll have to check my car and measure the joints to be sure, but I remember changing the joints years ago and I had no issues.
[Re: Vert]
#513634
11/05/09 12:36 AM
11/05/09 12:36 AM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Did you 'Upgrade'?
It came with it when he bought it.
