Too much gear #513257
11/01/09 02:46 PM
11/01/09 02:46 PM
Northern MN
Not a bee Offline OP
Northern MN
I'm just wondering if I have too much gear in my car. My peak horsepower on my dyno sheet is at 5500 rpm's, and I go through the traps at 6300. It's a 4.10 gear. What do you think, any opinions would be great.
By the way, I love the website.
Re: Too much gear [Re: Not a bee] #513258
11/01/09 04:58 PM
11/01/09 04:58 PM
Northern MN
Northern MN
How about some more info. The car is a 69 coronet. It weighs 3700 with driver. The motor is a 500in, 440. It makes 560 hp at 5500,and 620 tq at 3500. It has a 3000 conv. 4.10 gear with a 28in. tire. It runs 11.30's at 117 mph with 1.60 60 foot.
I was always told that you want to be as close to peak horse as possible through the traps, but I don't know for sure.
Re: Too much gear [Re: Not a bee] #513259
11/01/09 05:06 PM
11/01/09 05:06 PM
you might be a tad high, but you need that gear because your car is heavy.
you could go to a 29.5 tire, which would drop you down a little trough the traps.
your stuck in a catch 22 situation.
i wouldnt change the gears.
Re: Too much gear #513260
11/01/09 05:15 PM
11/01/09 05:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't think it's to much at all. could use some more tire and converter
Re: Too much gear #513261
11/01/09 05:22 PM
11/01/09 05:22 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I would definately go to a taller rear tire. It's easy enough to do.
Get out in front of the house and burn off what you have and then order a new set of tires.
Some say you want to be 10% past peak power in the traps.
SRT DEMON ONE SEAT
Re: Too much gear [Re: Not a bee] #513262
11/01/09 05:26 PM
11/01/09 05:26 PM
Northern MN
Northern MN
How about the intake. Its got a performer rpm. maybe a victor.
Re: Too much gear [Re: Ron Silva] #513263
11/01/09 05:40 PM
11/01/09 05:40 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Re: Too much gear [Re: B1KILLER] #513264
11/01/09 05:46 PM
11/01/09 05:46 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
with it peaking at 5500, i'm guessing it has a hyd. cam? if it has, it probably has stopped making power at that rpm.
Re: Too much gear [Re: tjmarcus1] #513265
11/01/09 05:55 PM
11/01/09 05:55 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Let me be the first to say
Post all the details of your set up. There are some truly knowledgable folks here that can let you know if somethings not matched for optimum performance or if your leaving something on the table.
And no,
I'm not one them
Re: Too much gear [Re: tjmarcus1] #513266
11/01/09 05:57 PM
11/01/09 05:57 PM
Northern MN
Northern MN
Solid flat tappet. .550/.570. I can't remember exactly the at .50 I think .250/.260.
Re: Too much gear [Re: Not a bee] #513267
11/01/09 07:04 PM
11/01/09 07:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am close to your combo in my 63. It weighs just over 3700 with me in the car and it is a .030 over 440 (446) with KB pistons and stock bottom end. I use 906 heads and the MP .557 cam. Holley Street Dominator intake and 850 DP. I run 4.30's with a 30" tire. I shift about 6200 and trap about 6400. Dynamic 9.5 converter flashes about 4200 and a best et of 11.52 @ 116. Best sixty is a 1.57. I feel I may go faster with a bit less gear as I am pretty well wound out going thru the traps. But if you have 4.10's and a 28" tire I would not go to less gear.
As for the Performer RPM it is a good intake. My son runs one on the 400 in his Dart and shifts about 6700. He has run 11.40's with the same basic combo as me but he has Eddy heads and he uses 3.91's with a 26" tire. I would think maybe more converter in your car rather then a gear change. Ron
Re: Too much gear [Re: Not a bee] #513268
11/01/09 07:34 PM
11/01/09 07:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well a victor is going to raise your peak HP RPM up a bunch and I like to be past peak so your using it all. that is the change I would consider!.
Re: Too much gear [Re: Not a bee] #513269
11/01/09 08:15 PM
11/01/09 08:15 PM
Northern MN
Northern MN
My slicks are shot. Maybe taller slicks and an intake. Or would that be to much.
Re: Too much gear [Re: Not a bee] #513270
11/02/09 02:46 AM
11/02/09 02:46 AM
What RPM are you shifting at in 1st and 2nd gear? If 5500 RPM or close to that try moving the shift points up to 5800 or 6000 RPM and see what that does before you change anything else. My Duster motor makes peak power on the engine dyno(two different tests on two different dynos two years apart) at 5600 RPM on the first tests with iron heads and 5800 RPM on the second tests with CNC ported Eddy RPM heads, the car runs faster shifing it at or above 7000 RPM in 1st and 2nd gear The first cuople of times I raced it I shifted it at 5400 rpm and 5600 RPM, it seemed like it spent a long time in high gear I switch tachs to a VDO Extreme playback and treid shifting a little higher, two to three hundred RPM each time. The tach never slows down on the play back, even shifting at 7500 RPM, where I get scared and move the lever anyways. The higher I shift it the faster it goes, that is with a Eddy six pak intake and stock type Holley carbs. I have treid 3:73, 3:91 and 4;10 in the car and it goes 128.6 with all three ratios some things don't make sense but they work anyways
Re: Too much gear [Re: Cab_Burge] #513271
11/02/09 07:46 PM
11/02/09 07:46 PM
Northern MN
Northern MN
I shift the car at 5800. I have tried from 5200 to 6500. It starts to run slower whene I start going over 6000.
Thanks for all the advice. If anybody has any other ideas let me know. thanks.
