Oil pan mystery?
#513248
11/01/09 01:24 PM
11/01/09 01:24 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I am putting together a 360 magnum for a 71 dart, bought a used oil pan that is supposedly for a 360 LA mid sump, as i went to install it, i notice both ends are the same size (larger size) that hold the overlapping gasket with the 2 dimples that you pull through, both ends have it this way, whats up with this, i'm lost? Obviously it doesn't fit the magnum, & yes i'm useing the LA oil pan gasket kit.
Re: Oil pan mystery?
[Re: BigTerry]
#513250
11/01/09 03:00 PM
11/01/09 03:00 PM
joedust451
super gas
super gas
Branson, Mo.
pictures?
I had a feeling some would want pics, i'll take one later. But i would think it would be a simple question for any mopar SB guru, its just like i discibed, both ends are the same & except the larger overlaping rubber gasket, i've never seen one like this.
[Re: Reggie]
#513253
11/01/09 03:42 PM
11/01/09 03:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if both ends are the same..it is a 318/340 pan...
360 pan has a smaller rear pan seal.
just like the pic above shows.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Reggie]
#513254
11/01/09 03:44 PM
11/01/09 03:44 PM
RapidRobert
the front/rear half moons are the same size on a 318/340 pan and different (from each other) on a 360
[Re: RapidRobert]
#513255
11/01/09 05:25 PM
11/01/09 05:25 PM
joedust451
super gas
super gas
Branson, Mo.
Well that explains it, well that just slammed the brakes on the install, had 3 days off to do it too . Now will the pickup be the same for the mid sump oil pans on any of the 3 because i have that?
