valve float
#513190
11/01/09 02:17 PM
11/01/09 02:17 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
what would the valve stem look like if I where getting into valve float I have lost .4 and 4-5 mph in the 1/8 I just run a comp test and a leak down test and found no problems there no more than 3% leakage
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: valve float
[Re: Dodgem]
#513192
11/01/09 02:32 PM
11/01/09 02:32 PM
dusturbd340W5
Kissimmee Fl.
solid roller lash has not changed converter only has about 25 passes motor sounds no different.
Re: valve float
[Re: emarine01]
#513194
11/01/09 03:58 PM
11/01/09 03:58 PM
dusturbd340W5
Kissimmee Fl.
I hear nothing but I have a few stems that have an odd looking pattern on the tip
Re: valve float
[Re: dusturbd340W5]
#513195
11/01/09 04:31 PM
11/01/09 04:31 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Valve float hammers the locks and retainers. Remove a few springs and check the lock OD and retainer ID for signs of trouble,you may also find the retainers difficult to remove.
Re: valve float
[Re: dusturbd340W5]
#513196
11/01/09 04:53 PM
11/01/09 04:53 PM
Posts: 1,019 Finland
mafo
Finland
I had a similar problem some years ago, checked everything, found nothing, until I put in new plug wires...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: valve float
[Re: mafo]
#513197
11/01/09 05:02 PM
11/01/09 05:02 PM
dusturbd340W5
Kissimmee Fl.
plug wires are MSD and only have about 50 passes on them
Re: valve float
[Re: dodgeboy11]
#513201
11/02/09 08:41 PM
11/02/09 08:41 PM
dusturbd340W5
Kissimmee Fl.
Erson solid roller 246/254@50 592 lift Crane lifters 65-6800
Re: valve float
[Re: dodgeboy11]
#513202
11/04/09 08:04 PM
11/04/09 08:04 PM
Posts: 3,638 Oakland, MI
dizuster
Oakland, MI
On those heads the valves shouldn't rotate much beyond their initial assembly. If you notice multiple (and by multiple, I mean more than two) roller patterns on the valve tip, this usually means it's floating.
That's a new one. What special thing makes these heads keep the valves from rotating?
http://www.youtube.com/watch?v=6Vz4mjPKXJ0&feature=related
Note that the valve and spring don't actually rotate as much per cycle as you see in this video. The video was taken with a low speed cameera, but with a strobe light flashing at the exact interval needed to make a smooth video. That way you don't need a SUPER high speed camera to capture each valve compression. Anyway... My point was that the spring/valve do rotate on all heads.
Re: valve float
[Re: dizuster]
#513203
11/04/09 11:12 PM
11/04/09 11:12 PM
Posts: 4,219 New York
polyspheric
New York
There are SpinTron vids around showing the entire spring pack (bottom cup and all 3 springs) jumping right off the head and squeezing together in the middle.
Can't sleep after watching that.
Boffin Emeritus
Re: valve float
[Re: dusturbd340W5]
#513204
11/04/09 11:25 PM
11/04/09 11:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats your spring pressure, both seat and open... what size valves... visible signs usually arent there but the engine will just lay there.... may still rev higher but with no power(slower to rev)
Re: valve float
[Re: dizuster]
#513205
11/04/09 11:31 PM
11/04/09 11:31 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Unless the spring has a rotator, the valve shouldn't rotate if the spring is doing it's job in keeping the valve under control. I've seen that video you're talking about but that's extreme RPM and showing what happens to the valve spring under those conditions. I've pulled tons of heads apart and only see two roller patterns on the tip of the valves. The first from when the engine was first started, and the second, after the spring rotated the valve a bit and the valve settled into it's position.
Oh and to answer your question, the spring, keepers and retainer are what keeps the valve from rotating. Unless it's a multi groove, then they'll spin as the grooves keep the retainer located and not the press on the valve stem as in a single groove setup.
Re: valve float
[Re: dodgeboy11]
#513206
11/05/09 12:21 AM
11/05/09 12:21 AM
dizuster
Oakland, MI
It's not the high speed... http://www.youtube.com/watch?v=019Jyn9oB5kInteresting though, I've seen some that rotate, and some that don't. In general it seems like the larger springs with an opposite wound inner spring rotate less vs. the single spring stuff. I can't see that it's related to valve float though because I found some really nasty valve float videos that didn't rotate, as well as some clean low RPM stuff that did rotate...
Re: valve float
[Re: RyanJ]
#513208
11/05/09 11:22 AM
11/05/09 11:22 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I understand offset rockers undergo extreme side loading themselves but, don't see any possible way a pushrod/rocker arm can transfer any side load to the valve stem. Prolonged intervals in tear-downs might result in stem wear perpendicular to the rocker shaft but, I can't envision the side loading. I'd be interested in the tech discussion.
Re: valve float
[Re: S/ST 3040]
#513209
11/05/09 11:35 AM
11/05/09 11:35 AM
polyspheric
New York
I agree - there are reliable reports of local wear, but exactly how does this happen? Is the long lever bending sideways as it depresses the stem?
Boffin Emeritus
